I am use to using the USB Multilink from P& E. That is all over now, I have to use the Tower system and make my PC board as big as the tower foot print. If I want to develop with ur micros.
Dennis Dice
Hi Dennis,
Most of the time the TWR board includes the OSBDM port and BDM/Jtag post.
By this way you can use the OSBDM (sample UBS cable between the PC and board) or a P&E interface as Multilink Universal.
If you are using CodeWarrior or KDS, the project wizard propose you to select both interfaces.
You will find more details under P&E web site:
Hope this will help
Pascal
NXP Technical Support
