About the part data needed by circuit diagram input.
masaakiuno
I input a circuit diagram using Toul as Concept of Cadence company soon.
When using this Concept, I want data of necessary LS1020A.
When the data is here, I can reduce time of the input of a circuit diagram.
Do you have that?
Maaski.Uno
ufedor
The LS1021A OrCAD symbol is attached.
I believe that it could be converted into the Concept one.
masaakiuno
Hi ufedor,
Thank you very much for your answer.
I'll try.
Maaski.Uno
masaakiuno
Hi ufedor,
They seem able to convert.
I defrosted the file I received this time, but an indicated symbol was only 1of14.
Does my method make a mistake?
Maaski.Uno
ufedor
Obtained result (1of14) seems to be incorrect.
Please apply to the Cadence technical support concerning correct conversion method.
