Change the RCW data
Change the RCW data
gyosunshim
Hi All,
I designed the T2081 board.
Use the SD card to boot.
During the boot logo below, I want to change the RCW value.
0x00000010 : 0x66150002 -> 0x6C150002
How do I change to apply?
Happy New Year!
gyosun.
addiyi
In uboot sources, under board\freescale\t208xrdb\ you can find cfg files for configure rcw and pbi. You can edit t2080_rcw.cfg and rebuild uboot for sd card.
Adrian
gyosunshim
Hi Adrian,
How do I apply t2080 rcw.cfg file on the SD card?
Please explain in more detail.
gyosun.
addiyi
This config file is picked when uboot is build and concatenate with the uboot image. After changing this file and rebuilding uboot, you have to load the new uboot into the sd card.
The sdcard uboot image contains rcw+pbi+uboot.
Adrian
gyosunshim
What are uboot only say that if you recompile to reload?
I'll try again if you fail question.
Thank you.
gyosun.
