Hi,all
On our board(MX6DL) we ported DDR on Android 5.0, and the board can not install APK,when installing, it will crash. But the same porting copy on Android 4.2, all is perfect. So Could you give me some explaination? Could I contact with FSL DDR RD to talk about this complicated problem? Could you give me the password about the porting xls? I need to know how my DDR parameters transition to DDR porting copy. And when encountered this problem, how to regulate my DDR porting?
Hi Tony
you can try to run Linux with new ddr, to know if APK issue
is related to ddr. Below resources devoted to porting new DDR :
i.MX6/7 DDR Stress Test Tool V2.40
i.MX6 DDR Stress Test Tool V1.0.3
https://community.freescale.com/docs/DOC-101708
In general you can elevate your requirements contacting local fae
and NXP Professional Services:
http://www.nxp.com/pages/freescale-professional-services:PROFESSIONAL-SERVICES
