Calibration of i.mx6 32bit bus DDR3 with 2 CS
Question asked by ZC Tee on Jan 4, 2016
Latest reply on Jan 5, 2016 by Yuri Muhin
Hi all,
i am trying to do calibration of the i.mx6 32bit bus DDR3 RAM with 2 Chip Select using the DDR Stress Test tool
My calibration always return failed if i tried to calibrate both CS together (select from the selection that prompt in the DDR Stress Test tool)
If i calibrate CS0 only, it will success.
I come across this article:
Re: 32bit bus width memory with 2 cs in IMX6Q
I tried to modified the MDMISC[CALIB_PER_CS] bit in the .inc file, but how do i confirm whether it's calibrating CS0 or CS1?
Is this method applicable with using the DDR Stress Test tool?
Thank you.
Tee
