I've got this problem to perform my activities . I would like a solution to this problem . Thank you very much in advance. The following message appears: "An error occured while connecting to the interface or target specified in the hardware launch config
Question asked by Rodrigo Caires on Jan 5, 2016
I've got this problem to perform my activities . I would like a solution to this problem . Thank you very much in advance. The following message appears: "An error occured while connecting to the interface or target specified in the hardware launch configuration Dialog . For this launch , you may retry / re -specify the connection with the Following parameters: USB Multilink -USB Port
Error launching teste1_FLASH_OpenSDA ARM GDI Protocol Adapter : Can't connect. The Debugger can not connect to the P&E device Thank you so much. Rodrigo rbcaires@gmail.com
Original Attachment has been moved to: 201601042110_DiagnosticInfo.zip
Original Attachment has been moved to: 201601042043_DiagnosticInfo.zip
Original Attachment has been moved to: 201601042049_DiagnosticInfo.zip
