MPC5604 eMIOS SAOCmode?
Question asked by BP HU on Jan 4, 2016
Latest reply on Jan 5, 2016 by Petr Stancik
hi,all:
i try to use the emios_0 channel18 in  SAOC mode to output a pulse. In the main(),  polling the EMIOS_0.CH[18].CSR.B.FLAG instead of using the interrupt.  but cannot find the FLAG set.
Here is the code:
(1)  how is BUS_ A's clock generated? how to confirm the clock work?                channel 18 has no internal clocks like channel 1-8, so choose the BUS_ A。
(2)  SAOC compared the data stored in the register A1 with internal counter, am i right?   what is the internal clock here?
(3) does the freeze mode matter when i use PE to debug SAOC,  i had disable the freeze mode ,but it didn't help.
emois_0_init()
  SIU.PCR[66].R = 0x0603;    //set as emios
  EMIOS_0.MCR.B.GPRE  = 63;        // global prescalser set 63
  EMIOS_0.MCR.B.GPREN = 1;         // prescaler enable
  EMIOS_0.MCR.B.GTBE  = 1;         // enable global time base
  EMIOS_0.MCR.B.FRZ   = 0;         // disable the freeze.
  EMIOS_0.CH[18].CCR.B.BSL   =  0;        //CLOCK select BUS_ A,
  EMIOS_0.CH[18].CCR.B.EDSEL  = 1;      //troggle
  EMIOS_0.CH[18].CCR.B.UCPRE =  0;      //prescaler set 1
  EMIOS_0.CH[18].CCR.B.UCPEN =  1;      //enable prescaler
  EMIOS_0.CH[18].CCR.B.FREN  =  0;      //disable freeze mode
  EMIOS_0.CH[18].CCR.B.FORCMA = 0;  //
  EMIOS_0.CH[18].CCR.B.FORCMB = 0;  //
  EMIOS_0.CH[18].CCR.B.MODE  =  3;    //select SAOC mode
  EMIOS_0.CH[18].CSR.B.FLAG  = 1;
  EMIOS_0.CH[18].CADR.R=5000;
the main:
main:
    SWT_DisableWatchDog();
    SYSTEM_Init();    //64MHZ
     emois_0_init();
// EnableExternalInterrupts();
   while(1)
      if(EMIOS_0.CH[18].CSR.B.FLAG  == 1)
      EMIOS_0.CH[18].CADR.R=500;
thank you very much for your time !!~
