Problem while launching a debug for openSDA for KL25Z128VLK4
bhupindersinghk
I am new to this board and KDS.
I was trying to execute a basic program to blink LED...
However while debugging the code through inbuilt openSDA a pop up windows shows as follows...
I have also tried re-installing the P&E drivers.But nothing seems to work.
Also I am certainly sure that I am following the bootloader updating process properly.
I have also tried installing KDS in different system however same error occurs. Even i have tried on different kl25z128vlk4 board but nothing works.
Please suggest any possible solution for this problem as soon as possible.
Hello ,
Which board do you use? FRDM-kl25? or your customer board ?
If the frdm-kl25, please drag the  file of "DEBUG-APP_Pemicro_v102.SDA" to the bootloader,
the plug in again the usb to  J7;
Then configure the debugger as this :
If still can not work , please take a screenshot about the process of your operate .
Alice
bhupindersinghk
Thanks Alice_Yang for your reply. I am using FRDM-kl25z128vlk4.
My debugging window looks as below:
While debugging, KDS hangs at 61% as shown in following window:
After this, P&E connection assistant window appears as shown below:
Please suggest the possible solution for this.
Hello ,
Have you test   drag and past the attachment i have send you , then debug ?
bhupindersinghk
Yes, But no effect
1 more thing, I got a window after P&E connection assistant. It is as shown:
After i cancel the P&E connection assistant window, error in services launch sequence appears.
Please test it on other PC , check the problem is the PC or the board .
Alice
bhupindersinghk
Hi Alice,
I have tried this on 2 PCs and even i have 2 boards. But I don't know why this problem occur.
Please help me out.
Bhupinder singh Khural
bhupindersinghk
Hi Alice,
No.
The same result. It shows first error with pop up window of "P&E connecion assistant" (as shown in above reply). Then the other pop up window shows "Error in services launch sequence".
I don't know where the problem is. I have checked in other system as well as in another kl25z board but it is showing same error.
Please help me out.
Hello Bhupinder,
It so strange ! From the debug configuration view , we can see the KDS has detect  the OpenSDA,
it should be connected well .At the Core option, does here have M0+? If have , please select M0+.
And what system do you used ?
If it still can not work , please take a picture for your board connection when debug .
Alice
bhupindersinghk
Hello Alice,
There is no M0+ in core option.
I am using KDS 3.0.0 in windows 7 PC. And i have also tried on KDS 1.1.1 in another windows 7 system.
Here, below is the image for connection of frdm kl25z:
Bhupinder singh khural
Hello
Please test my project on your side , use the KDS3.0 .
Alice
bhupindersinghk
I have tried your project on KDS 3.0 but it is not working.
Same things happened:
1. It showed P&E connection assistant window. (then i close this window and next thing happened)
2. Another window displayed that "Error in services launch sequence"
Oh, change one USB line .
bhupindersinghk
By changing USB line do you mean to change the USB wire between board and system?
Hello Bhupinder,
"I have tried this on 2 PCs and even i have 2 boards" , what about the result ?
Does the other FRDM-KL25 board can work well ?
