How to resolve the LS2085A QDS boot error
Question asked by Anandha Kumar M on Dec 27, 2015
Latest reply on Feb 3, 2016 by naveennvn
Hi All,
I'm using LS2085A QDS board and im facing errors like the following. The boot log is as followa
U-Boot 2015.07-rc1Layerscape2-SDK+g7e8bad0 (Oct 08 2015 - 20:08:11)
SoC:  LS2085E (0x87010010)
Clock Configuration:
       CPU0(A57):1600 MHz  CPU1(A57):1600 MHz  CPU2(A57):1600 MHz
       CPU3(A57):1600 MHz  CPU4(A57):1600 MHz  CPU5(A57):1600 MHz
       CPU6(A57):1600 MHz  CPU7(A57):1600 MHz
       Bus:      600  MHz  DDR:      1333.333 MT/s     DP-DDR:   1333.333 MT/s
Reset Configuration Word (RCW):
       00: 40282830 40400040 00000000 00000000
       10: 00000000 00200000 00200000 00000000
       20: 01812980 00002580 00000000 00000000
       30: 00000e0b 00000000 00000000 00000000
       40: 00000000 00000000 00000000 00000000
       50: 00000000 00000000 00000000 00000000
       60: 00000000 00000000 00027000 00000000
       70: 3f350000 00000000 00000000 00000000
Model: Freescale Layerscape 2085a QDS Board
Board: LS2085E-QDS, Board Arch: V1, Board version: B, boot from vBank: 0
FPGA: v5 (LS2085AQDS_2015_0218_1606), build 132 on Wed Feb 18 22:06:38 2015
SERDES1 Reference : Clock1 = 156.25MHz Clock2 = 100 separate SSCGMHz
SERDES2 Reference : Clock1 = 100 separate SSCGMHz Clock2 = 100 separate SSCGMHz
I2C:   ready
DRAM:  Initializing DDR....using SPD
Detected UDIMM 18ASF1G72AZ-2G1A1
Controler 0 timeout, debug_2 = 2100
Controler 0 timeout, debug_2 = 2500
Waiting for D_INIT timeout. Memory may not work.
Controler 1 timeout, debug_2 = 100
Controler 1 timeout, debug_2 = 1500
DP-DDR:  Detected UDIMM 18ASF1G72AZ-2G1A1
The errors are indicated in red color, please help me to fix this issue.
Note: I didnt change any DDR related files, all the default images are already loaded in the board..
