Fault input disable FTM output for KV11
Question asked by Administrator Employee on Dec 28, 2015
Latest reply on Dec 28, 2015 by jeremyzhou
Original Content posted by Li Yang
For KV11, the fault input is used for disable PWM output, could you help answer the following two questions?
1. If FTM0_FLT0 is enabled, all channels of FTM0 output are disabled or only FTM0_CH0/FTM0_CH1 are disabled?
2. Whether FTM1_FLT0 can be used to disable PWM output of FTM0_CH0/FTM0_CH1?
Thanks!
note:
The customer name is Suzhou Norlha, the project is electric wheelchair.
