processor expert can't open
andyvoss
I got processor expert in a condition where there were problems between components.  I tried to build PE code and before it finished I shut down my computer.  Now PE won't open or build.
Is there a simple way to re-build the PE code from existing information in the project or do I have to start over?
syedidris
Hi Andy,
Read the attached document which helps how to make PE & how to import PE examples step by step.
On page N0.18 you will find "Importing Example Projects" may be that will help you.
Hello ,
The PE is the Processor Expert IDE or the PE on  KDS ?
What's meaning PE won't open ? The project can not open ? Or does it show something when you open it ?
Or you can also send your project to me , i test it on my side .
Alice
andyvoss
Alice,
This is for the PE on KDS.
I started over and re-entered all of my software so everything is working again.  If there is an easy answer on how to get KDS's PE to rebuild, please let me know.  Otherwise, I won't pursue this problem any further.  I will be more careful not to interrupt processes in the future!
Andy.
Hello Andy,
When build project , if we interrupt the process , it can rebuild the PE project .
And i don't know what's the phenomenon on your side when rebuild the project ,
and if you refer to the DOC
