where is scatter-loading description
fatalfeel
Contributor V
where is the scatter-loading description in i.mx6
whats the file name
I need change it for long branch~~~
Labels (2)
fatalfeel
Contributor V
ok i find the topic
scatter file
where is freescale's scatter file location?
how to generate it?
Yuri
The simpest scatter file mau be found at
c:\Program Files\DS-5 v5.21.0\examples\Bare-metal_boards_examples.zip\DS-5Examples\Freescale-iMX6Q_RAM\scatter.scat
It uses internal RAM of i.MX6. You may change it for external DRAM, just changing
base address from 0x0090_0000 to 1000_0000, assuming initialization script provides
DRAM controller (MMDC) settings.
Yuri.
Yuri
   Please let me know more details about the problem.
Yuri
fatalfeel
Contributor V
thanks Yuri
ARM Information Center
i want to do long call/jump arm said edit scatter-loading description
but where is it? must have a file name or location
fatalfeel
Contributor V
Scatter-loading description file
The scatter-loading description file syntax shown in the following figure reflects the functionality provided by scatter-loading itself:ARM Information Center
Yuri
The scatter file depends on memory, used by an application.
An example for internal memory (OCRAM) may be found in attachment
of the following thread.
Integrating Processor Expert for i.MX and ARM GCC with Eclipse
General memory map of i.MX6 is described in Chapter 2
(Memory Maps) of the i.MX6 D/Q Reference Manual.
http://cache.nxp.com/files/32bit/doc/ref_manual/IMX6DQRM.pdf
Yuri.
