Android CTS 5.0 test fail in imx6 demo board
charleshuang
Senior Contributor II
Hi Freescale
We update the CTS 5.0 test R2 version in 12/31/2015.
Question 1:
We test CTS 5.0 R2 version in imx6 demo board again.
The result is some different.
Update the result.  Please reference about attachment. (2015.12.29_18.57.13.zip , device_logcat_758180884834948769.zip , host_log_1368752927456268592 )
1.    Compatibility Test Package: android.hardware:         android.hardware.consumerir.cts.ConsumerIrTest
       -- test_getCarrierFrequencies
       -- test_timing
       -- test_transmit
2.    Compatibility Test Package:  android.speech ABI:    android.speech.tts.cts.TextToSpeechTest
       -- testGetEnginesIncludesDefault
       -- testGetEnginesIncludesMock
       -- testSpeak
      -- testSynthesizeToFile
      -- testAndroidTestCaseSetupProperly
3.  (Compatibility Test Package: android.media)  android.media.cts.Vp8EncoderTest
      -- testEncoderQuality
Our platform have some cts fail issue in CTS5.0_R2 version.
If u have any solution, please provide to me.
(1)  (android.tests.appsecurity ) com.android.cts.appsecurity.AppSecurityTests
         -- testExternalStorageWrite
            junit.framework.AssertionFailedError: Failed external storage with write permissions at junit.framework.Assert.fail(Assert.java:50)
          (android.tests.appsecurity ) com.android.cts.appsecurity.SplitTests
         -- testApi -- testDensityAll -- testDensityBest -- testDensitySingle -- testDiffCert -- testDiffCertInherit -- testDiffVersion -- testDiffVersionInherit -- testDuplicateBase -- testDuplicateSplit --                        testFeatureApi -- testFeatureBase -- testLocale -- testNativeAll -- testNativeAllNatural -- testNativeSingle -- testNativeSingleNatural -- testSingleBase
            junit.framework.AssertionFailedError: Error: java.io.IOException: posix_fallocate failed: ENOTSUP (Operation not supported on transport endpoint)
(2)   (android.permission) android.permission.cts.FileSystemPermissionTest
         -- testIdletimerDirectoryExistsAndSan
           junit.framework.AssertionFailedError at junit.framework.Assert.fail(Assert.java:48)
(3)    This is test cts fail in out platform, but I have no any idea.   Do you have any advice for me?
      Compatibility Test Package:  android.bionic  -  android.bionic.fcntl   -- fallocate
      fail   :   bionic/tests/fcntl_test.cpp:123: Failure Value of: fallocate(tf.fd, 0, 0, 1)
Question 2:      We already just only find CTS5.0-R3 in google web.   And google is already update CTS 5.0  R3.
We test CTS 5.0 in imx6 demo board.
OS :  Android 5.0.2
CTS test version :  5.0_r3
Some fail issue we can not fixed it.  Please reference about attachment.
1.    Compatibility Test Package: android.core.tests.libcore.package.libcore ABI     libcore.javax.net.ssl.DefaultHostnameVerifierTest
        -- testWildcardMatchesWildcardSuffix
2.    Compatibility Test Package: android.hardware:         android.hardware.consumerir.cts.ConsumerIrTest
       -- test_timing
       -- test_transmit
3.    Compatibility Test Package:  android.speech ABI:    android.speech.tts.cts.TextToSpeechTest
       -- testSpeak
4.    Compatibility Test Package: android.widget ABI:    android.widget.cts.PopupWindowTest
      -- testGetMaxAvailableHeight
        android.widget.cts.VideoViewTest
       -- testPlayVideo1
Do you have any advice?
5.    This is test cts fail in out platform, but I have no any idea.   Do you have any advice for me?
Clayder
Labels (2)
