Good day every one .
How to compile the broad com wifi driver in linux kernel 3.14.28 version .Is it supported? where its located in driver file and make menuconfig.Can you explain how to cross compile and how to insert the modules on to the target board.
And how to bootup the wifi on imx6 target board.
And then how to boot from emmc on imx6 target board.send me emmc default bootargs .
Thanks & Regards
veera
Hi veeranjaneyulu
seems bcm4329 is used on wandboard, so one can look at its sources
http://wandboard.org/70-20140519-wandboard-rev-c1
https://github.com/wandboard-org/linux/tree/wandboard_imx_3.14.28_1.0.0_ga
