PARTITION_OUT_OF_BLOCKS in TCP/IP task every time our switch does periodic broadcast ARP scans
kecart
I am running MQX 4.1 on Kinetis MK61F120M.  Every 2 hours our company network scans to see what is connected and it causes the TCP/IP task to crash with PARTITION_OUT_OF_BLOCKS error.  I need to handle this condition but I don't know where to look.  Increasing the partition size would not prevent a DOS attack from causing the same error. Any suggestions on how to handle this?
Martin_
MQX 4.2 (RTCS v4.2.0) fixes this
