Macro: Terminate, Clean, Build, Debug
ignisuti_
Is there a way in KDS to setup a Hotkey/Macro to execute the following functions?
Terminate, Clean, Build, and then Debug
ZhangJennie
Hi Joe,
KDS3.0 doesn't have feature of define key bindings sequence.
it is more an eclipse feature.  here is some solution for eclipse:
FAQ How do I create my own key-binding configuration? - Eclipsepedia
Eclipse Commands Advanced - Tutorial
Define key bindings for Eclipse Commands - Tutorial
Hope this helps!
Jennie Zhang
ZhangJennie
Hi Joe,
I suggest you go to IDE menu windows, preferences to view/modify the command hotkey.
see attached video.
can this help you?
Jennie Zhang
