I try building sdk of poky(1.8) for build qt.
I want to build the sdk contains gstreamer1.0.
But,by defualt, the sdk contains gstreamer0.1.
How can I make the sdk contains gstreamer1.0?
Add gstreamer1.0 to your image... For me I added the line to <build_dir>/conf/locale.conf
CORE_IMAGE_EXTRA_INSTALL += "packagegroup-fsl-gstreamer1.0-full"
Then, bitbake your image..
$bitbake core-image-x11
Then, make the sdk
$bitbake core-image-x11 -c populate_sdk_ext
Then install that sdk and you should have gstreamer in it.
HI G
please look at Gstreamer tutorial
i.MX6 GStreamer-imx Plugins - Tutorial & Example Pipelines
Hi igor
Thank you for the information.
I can build gst 1.0 into images.
But I can build it into sdk.
I don't know how to build it into sdk.
G
Hi G
what do you mean by "build it into sdk" ?
~igor
Hi igor
I'm sorry for my poor english.
I build sdk by "bitbake meta-toolchain-qt".
Then install sdk(toolchain) by "poky-glibc-x86_64-meta-toolchain-qt-cortexa9hf-vfp-neon-toolchain-qt-1.8.sh"
In this way, the sdk(toolchain) contains gst 0.1 only.
I need gst. 1.0.
But I don't know how to do it.
G
