is m-sata available on LS1020A?
Question asked by shawnreuland on Dec 20, 2015
Latest reply on Dec 20, 2015 by ufedor
Hello, how is m-sata enabled with LS1020A? I see the tower dev board, TWR-LS1021A, fact sheet
http://cache.nxp.com/files/32bit/doc/fact_sheet/TWRLS1021AFS.pdf?fpsp=1&WT_TYPE=Fact%20Sheets&WT_VENDOR=FREESCALE&WT_FIL…
mentions (1) m-sata slot, and the LS1021A iot reference mentions the same m-sata slot:
http://cache.nxp.com/files/32bit/doc/fact_sheet/LS1IoTGTWYFS.pdf?fpsp=1&WT_TYPE=Fact%20Sheets&WT_VENDOR=FREESCALE&WT_FIL…
however, in both cases, it doesn't look like there is a slot on the board pics, just two plain pci-e, correct? Just want to confirm, can a design incorporate a third pci-e slot be connected to LS1020A in conjunction with its sata controller in order to support m-sata card plugins?
