IMX6 SABRE-SD boot hung issue
Question asked by David King on Dec 18, 2015
Latest reply on Dec 18, 2015 by igorpadykov
Dear all,
I met hung problem when booting SABRE-SD from SD card, the followings are uboot version bootargs and logcat for android.
It seems that GPU crash almost every time, is there anyone met the same problem?
U-Boot 2009.08 (Jun 21 2013 - 22:41:23)
CPU: Freescale i.MX6 family TO1.2 at 792 MHz
Thermal sensor with ratio = 186
Temperature:   46 C, calibration data 0x59a4d87d
mx6q pll1: 792MHz
mx6q pll2: 528MHz
mx6q pll3: 480MHz
mx6q pll8: 50MHz
ipg clock     : 66000000Hz
ipg per clock : 66000000Hz
uart clock    : 80000000Hz
cspi clock    : 60000000Hz
ahb clock     : 132000000Hz
axi clock   : 264000000Hz
emi_slow clock: 132000000Hz
ddr clock     : 528000000Hz
usdhc1 clock  : 198000000Hz
usdhc2 clock  : 198000000Hz
usdhc3 clock  : 198000000Hz
usdhc4 clock  : 198000000Hz
nfc clock     : 24000000Hz
Board: i.MX6Q-SABRESD: unknown-board Board: 0x63012 [POR ]
Boot Device: SD
I2C:   ready
DRAM:   1 GB
MMC:   FSL_USDHC: 0,FSL_USDHC: 1,FSL_USDHC: 2,FSL_USDHC: 3
In:    serial
Out:   serial
Err:   serial
i2c: I2C3 SDA is low, start i2c recovery...
I2C3 Recovery success
Found PFUZE100! deviceid=10,revid=11
Net:   got MAC address from IIM: 00:04:9f:02:6b:77
FEC0 [PRIME]
Hit any key to stop autoboot:  0
MX6Q SABRESD U-Boot >
MX6Q SABRESD U-Boot > pri
bootdelay=3
baudrate=115200
ipaddr=192.168.1.103
serverip=192.168.1.101
netmask=255.255.255.0
loadaddr=0x10800000
rd_loadaddr=0x11000000
netdev=eth0
ethprime=FEC0
splashimage=0x30000000
splashpos=m,m
lvds_num=1
ethact=FEC0
bootargs=console=ttymxc0,115200 androidboot.console=ttymxc0 vmalloc=400M init=/init video=mxcfb0:dev=hdmi,1920x1080M@60,bpp=32 video=mxcfb1:off video=mxcfb2:off fbmem=28M androidboot.hardware=freescale
stdin=serial
stdout=serial
stderr=serial
fastboot_dev=mmc2
bootcmd=booti mmc2
Environment size: 503/8188 bytes
snvs_rtc snvs_rtc.0: setting system clock to 1970-01-01 00:00:01 UTC (1)
Freeing init memory: 244K
init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
android_usb: already disabled
mtp_bind_config
input: eCompass as /devices/virtual/input/input8
root@android:/ #
root@android:/ #
root@android:/ #
root@android:/ # ERROR: v4l2 capture: slave not found!
init: untracked pid 2356 exited
init: untracked pid 2351 exited
init: untracked pid 2646 exited
init: untracked pid 2647 exited
init: untracked pid 2764 exited
init: untracked pid 2766 exited
init: untracked pid 2765 exited
init: untracked pid 2983 exited
init: untracked pid 2982 exited
init: untracked pid 3200 exited
init: untracked pid 3199 exited
init: untracked pid 3418 exited
init: untracked pid 3417 exited
init: untracked pid 3635 exited
init: untracked pid 3634 exited
init: untracked pid 3852 exited
init: untracked pid 3851 exited
root@android:/ #
root@android:/ #
root@android:/ # logcat&
[1] 4289
root@android:/ # --------- beginning of /dev/log/main
I/installd( 2358): installd firing up
D/        ( 2361): init_sensors
D/        ( 2361): find sensor name mma845x
D/        ( 2361): input device 'mma845x' opened, fd = 8
D/        ( 2361): find sensor name mag3110
D/        ( 2361): input device 'mag3110' opened, fd = 10
D/MagDaemon( 2361): magnetic sensor calibrate daemon start
I/OrionSvc( 2365): Set command is setprop athr.gps.conf /system/etc/gps/Orion.ini
D/MagCalibrated( 2361): fl_calib = 0
D/MagDaemon( 2361): magnetic calibrate daemon set threshold 100.000000
I/OrionSvc( 2365): using prop value
I/OrionSvc( 2365): Get key ANDROID_SOCKET_athrshmsocket on 11
I/OrionSvc( 2365): Enter control_ipc thread
--------- beginning of /dev/log/system
I/Vold    ( 2350): Vold 2.1 (the revenge) firing up
D/Vold    ( 2350): Volume udisk state changing -1 (Initializing) -> 0 (No-Media)
init: untracked pid 4068 exited
init: untracked pid 4069 exited
D/Vold    ( 2350): Volume extsd state changing -1 (Initializing) -> 0 (No-Media)
I/Netd    ( 2351): Netd 1.0 starting
W/InterfaceController( 2351): Warning (Cannot load library: load_library(linker.cpp:745): library "/system/lib/libnetcmdiface.so" not found) while opening the net interface command library
I/DEBUG   ( 2352): debuggerd: Dec 17 2015 10:36:05
D/MDnsDS  ( 2351): MDnsSdListener::Hander starting up
D/MDnsDS  ( 2351): MDnsSdListener starting to monitor
D/MDnsDS  ( 2351): Going to poll with pollCount 1
I/SurfaceFlinger( 2353): SurfaceFlinger is starting
I/SurfaceFlinger( 2353): SurfaceFlinger's main thread ready to run. Initializing graphics H/W...
D/libEGL  ( 2353): loaded /system/lib/egl/libEGL_VIVANTE.so
D/libEGL  ( 2353): loaded /system/lib/egl/libGLESv1_CM_VIVANTE.so
D/libEGL  ( 2353): loaded /system/lib/egl/libGLESv2_VIVANTE.so
W/imx6.gralloc( 2353): 32bpp setting of Framebuffer catched!
W/imx6.gralloc( 2353): using (fd=15)
W/imx6.gralloc( 2353): id           = DISP4 BG
W/imx6.gralloc( 2353): xres         = 640 px
W/imx6.gralloc( 2353): yres         = 480 px
W/imx6.gralloc( 2353): xres_virtual = 640 px
W/imx6.gralloc( 2353): yres_virtual = 1536 px
W/imx6.gralloc( 2353): bpp          = 32
W/imx6.gralloc( 2353): r            =  0:8
W/imx6.gralloc( 2353): g            =  8:8
W/imx6.gralloc( 2353): b            = 16:8
W/imx6.gralloc( 2353): width        = 340 mm (47.811764 dpi)
W/imx6.gralloc( 2353): height       = 270 mm (45.155556 dpi)
W/imx6.gralloc( 2353): refresh rate = 60.00 Hz
I/FslHwcomposer( 2353): fb0 is hdmi
I/FslHwcomposer( 2353):  device
I/FslHwcomposer( 2353): fb0 device plugin
I/FslHwcomposer( 2353): fb1 is overlay device
W/FslHwcomposer( 2353): open /sys/class/graphics/fb2 failed
W/FslHwcomposer( 2353): open /sys/class/graphics/fb3 failed
W/FslHwcomposer( 2353): open /sys/class/graphics/fb4 failed
W/FslHwcomposer( 2353): open /sys/class/graphics/fb5 failed
I/FslHwcomposer( 2353): hwcomposer: open framebuffer fb0
I/mediaserver( 2356): ServiceManager: 0x41073000
I/AudioFlinger( 2356): Using default 3000 mSec as standby time.
I/CameraService( 2356): CameraService started (pid=2356)
I/v_hwc   ( 2353): Detected display /dev/graphics/fb0
I/v_hwc   ( 2353): xres         = 640 px
I/v_hwc   ( 2353): yres         = 480 px
I/v_hwc   ( 2353): xres_virtual = 640 px
I/v_hwc   ( 2353): yres_virtual = 1536 px
I/v_hwc   ( 2353): width        = 340 mm (47.8 dpi)
I/v_hwc   ( 2353): height       = 270 mm (45.2 dpi)
I/v_hwc   ( 2353): refresh rate = 60.0 Hz
E/v_hwc   ( 2353): open /dev/graphics/fb0 failed
I/v_hwc   ( 2353): Vivante HWComposer v2.4
I/v_hwc   ( 2353): Device:               0x400b60d0
I/v_hwc   ( 2353): Separated 2D:         YES
I/v_hwc   ( 2353): 2D PE20:              YES
I/v_hwc   ( 2353): Multi-source blit:    NO
I/v_hwc   ( 2353): Multi-source blit Ex: NO
I/v_hwc   ( 2353): OPF/YUV blit/Tiling : NO
I/v_hwc   ( 2353): Filter stretch      : YES
I/FslHwcomposer( 2353): hwc_device_open,367
I/SurfaceFlinger( 2353): Using composer version 1.1
W/SurfaceFlinger( 2353): no suitable EGLConfig found, trying without EGL_FRAMEBUFFER_TARGET_ANDROID
I/FslCameraHAL( 2356): Face Back Camera is ov5640_mipi, orient is 0
I/FslCameraHAL( 2356): Face Front Camera is uvc,ov5642_camera,ov5640_camera, orient is 0
I/FslCameraHAL( 2356): Checking the camera ov5640_mipi
E/SurfaceFlinger( 2353): HWComposer: framebufferTarget is null
I/SurfaceFlinger( 2353): EGL informations:
I/SurfaceFlinger( 2353): vendor    : Android
I/SurfaceFlinger( 2353): version   : 1.4 Android META-EGL
I/SurfaceFlinger( 2353): extensions: EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_KHR_gl_texture_2D_image EGL_KHR_gl_renderbuffer_image EGL_KHR_fence_sync EGL_ANDROID_image_native_buffer
I/SurfaceFlinger( 2353): Client API: OpenGL_ES
I/SurfaceFlinger( 2353): EGLSurface: 8-8-8-8, config=0x4ba9a870
I/SurfaceFlinger( 2353): OpenGL ES informations:
I/SurfaceFlinger( 2353): vendor    : Vivante Corporation
I/SurfaceFlinger( 2353): renderer  : GC2000 Graphics Engine
I/SurfaceFlinger( 2353): version   : OpenGL ES-CM 1.1
I/SurfaceFlinger( 2353): extensions: GL_EXT_debug_marker GL_OES_blend_equation_separate GL_OES_blend_func_separate GL_OES_blend_subtract GL_OES_byte_coordinates GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_draw_texture GL_OES_extended_matrix_palette GL_OES_fixed_point GL_OES_framebuffer_object GL_OES_matrix_get GL_OES_matrix_palette GL_OES_point_size_array GL_OES_point_sprite GL_OES_query_matrix GL_OES_read_format GL_OES_single_precision GL_OES_stencil_wrap GL_OES_texture_cube_map GL_OES_texture_mirrored_repeat GL_OES_EGL_image GL_OES_depth24 GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_mapbuffer GL_OES_rgb8_rgba8 GL_OES_stencil1 GL_OES_stencil4 GL_OES_stencil8 GL_OES_texture_npot GL_OES_vertex_half_float GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_IMG_read_format GL_IMG_user_clip_plane GL_APPLE_texture_2D_limited_npot GL_EXT_texture_lod_bias GL_EXT_blend_minmax GL_EXT_read_format_bgra GL_EXT_multi_draw_arrays GL_OES_EGL_sync GL_APPLE_texture_format_BGRA8888 GL_APPLE_te
I/SurfaceFlinger( 2353): GL_MAX_TEXTURE_SIZE = 8192
I/SurfaceFlinger( 2353): GL_MAX_VIEWPORT_DIMS = 8192 x 8192
I/FslCameraHAL( 2356): Checking the camera uvc
I/FslCameraHAL( 2356): Checking the camera ov5642_camera
I/FslCameraHAL( 2356): Checking the camera ov5640_camera
D/SurfaceFlinger( 2353): Screen acquired, type=0 flinger=0x400b43a8
I/AudioPolicyManagerBase( 2356): loadAudioPolicyConfig() loaded /system/etc/audio_policy.conf
W/audio_hw_primary( 2356): card 0, id wm8962audio ,driver wm8962-audio, name wm8962-audio
W/audio_hw_primary( 2356): out rate 44100
W/audio_hw_primary( 2356): in rate 44100, channels 1 format 0
W/audio_hw_primary( 2356): card 1, id imxhdmisoc ,driver imx-hdmi-soc, name imx-hdmi-soc
W/audio_hw_primary( 2356): in rate 0, channels 0 format 0
I/AudioFlinger( 2356): loadHwModule() Loaded primary audio interface from Freescale i.MX Audio HW HAL (audio) handle 1
W/audio_hw_primary( 2356): open output stream devices 2, format 1, channels 3, sample_rate 44100, flag 2
W/audio_hw_primary( 2356): opened out stream...1074269248
I/AudioFlinger( 2356): HAL output buffer size 192 frames, normal mix buffer size 768 frames
D/AndroidRuntime( 2354):
D/AndroidRuntime( 2354): >>>>>> AndroidRuntime START com.android.internal.os.ZygoteInit <<<<<<
D/AndroidRuntime( 2354): CheckJNI is OFF
I/AndroidRuntime( 2354): JNI options: '-Xjniopts:warnonly'
D/libEGL  ( 2639): loaded /system/lib/egl/libEGL_VIVANTE.so
D/libEGL  ( 2639): loaded /system/lib/egl/libGLESv1_CM_VIVANTE.so
D/libEGL  ( 2639): loaded /system/lib/egl/libGLESv2_VIVANTE.so
E/BufferQueue( 2353): [BootAnimation] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
I/AudioMixer( 2356): found effect "Multichannel Downmix To Stereo" from The Android Open Source Project
E/MonoPipe( 2356): Failed to fetch local time frequency when constructing a MonoPipe (res = -32).  getNextWriteTimestamp calls will be non-functional
I/v_hwc   ( 2353): Display(0x4005c008) detected: format=306 640x480
I/v_hwc   ( 2353): Display buffer(0x40035590) detected: physical=0x4e400000
I/v_hwc   ( 2353): Display buffer(0x400355b8) detected: physical=0x4e52c000
I/v_hwc   ( 2353): Display buffer(0x401afb88) detected: physical=0x4e658000
D/dalvikvm( 2354): Trying to load lib libjavacore.so 0x0
D/dalvikvm( 2354): Added shared lib libjavacore.so 0x0
D/dalvikvm( 2354): Trying to load lib libnativehelper.so 0x0
D/dalvikvm( 2354): Added shared lib libnativehelper.so 0x0
F/libc    ( 2354): Fatal signal 11 (SIGSEGV) at 0x00000000 (code=1), thread 2354 (zygote)
I/DEBUG   ( 2352): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
I/DEBUG   ( 2352): Build fingerprint: 'Freescale/sabresd_6dq/sabresd_6dq:4.2.2/1.1.0-rc3/eng.hgeng.20151217.102144:user/dev-keys'
I/DEBUG   ( 2352): Revision: '405522'
I/DEBUG   ( 2352): pid: 2354, tid: 2354, name: zygote  >>> zygote <<<
I/DEBUG   ( 2352): signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 00000000
I/DEBUG   ( 2352):     r0 be988bbc  r1 41d3f830  r2 40123010  r3 61d698a0
I/DEBUG   ( 2352):     r4 40123010  r5 00000000  r6 407fc294  r7 41104f78
I/DEBUG   ( 2352):     r8 be988be0  r9 41104f78  sl 40123020  fp be988bf4
I/DEBUG   ( 2352):     ip 00000069  sp be988be8  lr 40827231  pc 00000000  cpsr 20000030
I/DEBUG   ( 2352):     d0  00a7d8c02f757856  d1  0000000000000000
I/DEBUG   ( 2352):     d2  0000000000000000  d3  0000000000000000
I/DEBUG   ( 2352):     d4  0000000000000000  d5  0000000000000000
I/DEBUG   ( 2352):     d6  0000030000000000  d7  4088000000000000
I/DEBUG   ( 2352):     d8  0000000000000000  d9  0000000000000000
I/DEBUG   ( 2352):     d10 0000000000000000  d11 0000000000000000
I/DEBUG   ( 2352):     d12 0000000000000000  d13 0000000000000000
I/DEBUG   ( 2352):     d14 0000000000000000  d15 0000000000000000
I/DEBUG   ( 2352):     d16 4090000000000000  d17 3fe8000000000000
I/DEBUG   ( 2352):     d18 41c7babc2b000000  d19 3fe8000000000000
I/DEBUG   ( 2352):     d20 0000000000000000  d21 0000000000000000
I/DEBUG   ( 2352):     d22 0000000000000000  d23 0000000000000000
I/DEBUG   ( 2352):     d24 0000000000000000  d25 0000000000000000
I/DEBUG   ( 2352):     d26 0000000000000000  d27 0000000000000000
I/DEBUG   ( 2352):     d28 0000000000000000  d29 0000000000000000
I/DEBUG   ( 2352):     d30 0000000000000000  d31 0000000000000000
I/DEBUG   ( 2352):     scr 80000010
I/DEBUG   ( 2352):
I/DEBUG   ( 2352): backtrace:
I/DEBUG   ( 2352):     #00  pc 00000000  <unknown>
I/DEBUG   ( 2352):     #01  pc 0004922d  /system/lib/libdvm.so
I/DEBUG   ( 2352):     #02  pc 00000004  <unknown>
I/DEBUG   ( 2352):
I/DEBUG   ( 2352): stack:
I/DEBUG   ( 2352):          be988ba8  40827361  /system/lib/libdvm.so
I/DEBUG   ( 2352):          be988bac  40827231  /system/lib/libdvm.so
I/DEBUG   ( 2352):          be988bb0  41d4ac80  /dev/ashmem/dalvik-heap (deleted)
I/DEBUG   ( 2352):          be988bb4  40827389  /system/lib/libdvm.so
I/DEBUG   ( 2352):          be988bb8  41d3f830  [heap]
I/DEBUG   ( 2352):          be988bbc  40123010
I/DEBUG   ( 2352):          be988bc0  41d4ac80  /dev/ashmem/dalvik-heap (deleted)
I/DEBUG   ( 2352):          be988bc4  41d3f830  [heap]
I/DEBUG   ( 2352):          be988bc8  1d200005
I/DEBUG   ( 2352):          be988bcc  641b284f  /system/lib/libjavacore.so
I/DEBUG   ( 2352):          be988bd0  61d698a0  /dev/ashmem/dalvik-LinearAlloc (deleted)
I/DEBUG   ( 2352):          be988bd4  40123010
I/DEBUG   ( 2352):          be988bd8  00000000
I/DEBUG   ( 2352):          be988bdc  407fc294  /system/lib/libdvm.so (dvmPlatformInvoke+116)
I/DEBUG   ( 2352):          be988be0  df0027ad
I/DEBUG   ( 2352):          be988be4  00000000
I/DEBUG   ( 2352):     #00  be988be8  41d4a580  /dev/ashmem/dalvik-heap (deleted)
I/DEBUG   ( 2352):          ........  ........
I/DEBUG   ( 2352):     #01  be988be8  41d4a580  /dev/ashmem/dalvik-heap (deleted)
I/DEBUG   ( 2352):          be988bec  00000008
I/DEBUG   ( 2352):     #02  be988bf0  00000000
I/DEBUG   ( 2352):          be988bf4  4082b415  /system/lib/libdvm.so (dvmCallJNIMethod(unsigned int const*, JValue*, Method const*, Thread*)+400)
I/DEBUG   ( 2352):          be988bf8  41104f78
I/DEBUG   ( 2352):          be988bfc  62f61b36  /system/framework/core.odex
I/DEBUG   ( 2352):          be988c00  641b2855  /system/lib/libjavacore.so
I/DEBUG   ( 2352):          be988c04  40123020
I/DEBUG   ( 2352):          be988c08  1d200005
I/DEBUG   ( 2352):          be988c0c  00000000
I/DEBUG   ( 2352):          be988c10  40123010
I/DEBUG   ( 2352):          be988c14  4021b228
I/DEBUG   ( 2352):          be988c18  41105000  /dev/ashmem/dalvik-aux-structure (deleted)
I/DEBUG   ( 2352):          be988c1c  00000002
I/DEBUG   ( 2352):          be988c20  00000001
I/DEBUG   ( 2352):          be988c24  41d4a580  /dev/ashmem/dalvik-heap (deleted)
I/DEBUG   ( 2352):          be988c28  40123010
I/DEBUG   ( 2352):          be988c2c  40848d51  /system/lib/libdvm.so (dvmInitClass+1196)
I/DEBUG   ( 2352):
I/DEBUG   ( 2352): memory near r0:
I/DEBUG   ( 2352):     be988b9c 40827215 be988bbc 00000025 40827361
I/DEBUG   ( 2352):     be988bac 40827231 41d4ac80 40827389 41d3f830
I/DEBUG   ( 2352):     be988bbc 40123010 41d4ac80 41d3f830 1d200005
I/DEBUG   ( 2352):     be988bcc 641b284f 61d698a0 40123010 00000000
I/DEBUG   ( 2352):     be988bdc 407fc294 df0027ad 00000000 41d4a580
I/DEBUG   ( 2352):     be988bec 00000008 00000000 4082b415 41104f78
I/DEBUG   ( 2352):     be988bfc 62f61b36 641b2855 40123020 1d200005
I/DEBUG   ( 2352):     be988c0c 00000000 40123010 4021b228 41105000
I/DEBUG   ( 2352):     be988c1c 00000002 00000001 41d4a580 40123010
I/DEBUG   ( 2352):     be988c2c 40848d51 40123010 41d4a580 00000003
I/DEBUG   ( 2352):     be988c3c 41d4a580 40123010 40887c98 41d4cb88
I/DEBUG   ( 2352):     be988c4c 40123ed0 be988cbc 61d698b4 00000001
I/DEBUG   ( 2352):     be988c5c 41d4a580 00000001 61d698a0 00000428
I/DEBUG   ( 2352):     be988c6c 62f7b447 00000012 00000001 be988cbc
I/DEBUG   ( 2352):     be988c7c 40848ebd 62f7b447 41d4a580 62f7b447
I/DEBUG   ( 2352):     be988c8c 000044f8 41105000 41d4a580 62f7b447
I/DEBUG   ( 2352):
I/DEBUG   ( 2352): memory near r1:
I/DEBUG   ( 2352):     41d3f810 be9891c4 402c4075 00000000 00000000
I/DEBUG   ( 2352):     41d3f820 00000000 00000000 00000000 00000023
I/DEBUG   ( 2352):     41d3f830 40885334 00000000 00000001 40123010
I/DEBUG   ( 2352):     41d3f840 00000000 00000000 00000000 00000013
I/DEBUG   ( 2352):     41d3f850 0000002e 00000000 00000000 00000153
I/DEBUG   ( 2352):     41d3f860 7379732f 2f6d6574 6d617266 726f7765
I/DEBUG   ( 2352):     41d3f870 6f632f6b 6a2e6572 2f3a7261 74737973
I/DEBUG   ( 2352):     41d3f880 662f6d65 656d6172 6b726f77 726f632f
I/DEBUG   ( 2352):     41d3f890 756a2d65 2e74696e 3a72616a 7379732f
I/DEBUG   ( 2352):     41d3f8a0 2f6d6574 6d617266 726f7765 6f622f6b
I/DEBUG   ( 2352):     41d3f8b0 79636e75 74736163 6a2e656c 2f3a7261
I/DEBUG   ( 2352):     41d3f8c0 74737973 662f6d65 656d6172 6b726f77
I/DEBUG   ( 2352):     41d3f8d0 7478652f 72616a2e 79732f3a 6d657473
I/DEBUG   ( 2352):     41d3f8e0 6172662f 6f77656d 662f6b72 656d6172
I/DEBUG   ( 2352):     41d3f8f0 6b726f77 72616a2e 79732f3a 6d657473
I/DEBUG   ( 2352):     41d3f900 6172662f 6f77656d 742f6b72 70656c65
I/DEBUG   ( 2352):
I/DEBUG   ( 2352): memory near r2:
I/DEBUG   ( 2352):     40122ff0 00000000 00000000 00000000 00000000
I/DEBUG   ( 2352):     40123000 00000000 00000000 00000000 00000453
I/DEBUG   ( 2352):     40123010 62ead0e0 41104f78 61d694b0 41105000
I/DEBUG   ( 2352):     40123020 00000000 00000000 be988d08 00000000
I/DEBUG   ( 2352):     40123030 be988d3c 00000001 00000000 407fc400
I/DEBUG   ( 2352):     40123040 00000000 00000000 40f81870 410ff300
I/DEBUG   ( 2352):     40123050 00000000 00000000 00000001 00006000
I/DEBUG   ( 2352):     40123060 00000000 400d33dc 407fc400 408012c0
I/DEBUG   ( 2352):     40123070 00000000 408053bc 40805430 408052e0
I/DEBUG   ( 2352):     40123080 40805300 4080535c 00000000 00000000
I/DEBUG   ( 2352):     40123090 00000000 00000000 00000000 00000000
I/DEBUG   ( 2352):     401230a0 00000000 00000000 00002000 4088c8d4
I/DEBUG   ( 2352):     401230b0 00000000 00000000 00000002 41d3fbf8
I/DEBUG   ( 2352):     401230c0 00000001 00000040 00000200 00000000
I/DEBUG   ( 2352):     401230d0 00000000 00000000 00000000 00000000
I/DEBUG   ( 2352):     401230e0 00000000 00000000 00000000 00000000
I/DEBUG   ( 2352):
I/DEBUG   ( 2352): memory near r3:
I/DEBUG   ( 2352):     61d69880 000002f6 62f34990 62eaeab4 00000000
I/DEBUG   ( 2352):     61d69890 00000000 00000000 6307bf51 00000000
I/DEBUG   ( 2352):     61d698a0 41d4a580 0000010a 00000000 00000000
I/DEBUG   ( 2352):     61d698b0 62f7b447 40123ed0 00000943 62f61b36
I/DEBUG   ( 2352):     61d698c0 641b2855 00000000 4082b285 00000100
I/DEBUG   ( 2352):     61d698d0 00000000 00000000 41d4a580 0000000a
I/DEBUG   ( 2352):     61d698e0 00010000 00000000 62f852f4 40123ed0
I/DEBUG   ( 2352):     61d698f0 00000030 62f314ed 62eaeb64 00000000
I/DEBUG   ( 2352):     61d69900 00000000 00000000 6307bf85 00000000
I/DEBUG   ( 2352):     61d69910 00000000 0000002c 61d41080 61d410b8
I/DEBUG   ( 2352):     61d69920 61d410f0 61d41128 61d41160 61d41198
I/DEBUG   ( 2352):     61d69930 61d411d0 61d41208 61d41240 61d41278
I/DEBUG   ( 2352):     61d69940 61d412b0 00000004 41d4cc50 0000018c
I/DEBUG   ( 2352):     61d69950 41d4cba8 00010000 00010000 00010001
I/DEBUG   ( 2352):     61d69960 62f248d2 40123ed0 00000943 62f61b36
I/DEBUG   ( 2352):     61d69970 62eaeb78 00000000 00000000 00000000
I/DEBUG   ( 2352):
I/DEBUG   ( 2352): memory near r4:
I/DEBUG   ( 2352):
I/DEBUG   ( 2352): memory near r6:
I/DEBUG   ( 2352):     407fc274 3497c004 3488c004 3afffff9 e2888004
I/DEBUG   ( 2352):     407fc284 eafffff9 e899000c e59bc00c e12fff3c
I/DEBUG   ( 2352):     407fc294 e3560000 159bc010 e24bd014 188c0003
I/DEBUG   ( 2352):     407fc2a4 e8bd8bc0 e1a0ce22 e59b6008 e2866001
I/DEBUG   ( 2352):     407fc2b4 e3a02000 e4d6c001 e35c0000 0a000007
I/DEBUG   ( 2352):     407fc2c4 e2822001 e35c0044 135c004a 1afffff8
I/DEBUG   ( 2352):     407fc2d4 e3120001 12822001 02822002 eafffff4
I/DEBUG   ( 2352):     407fc2e4 e2522002 43b02000 0affffe5 e04dd102
I/DEBUG   ( 2352):     407fc2f4 e3cdd004 e1a07009 e1a0800d e59b6008
I/DEBUG   ( 2352):     407fc304 e2866001 e2877008 e4d6c001 e35c0044
I/DEBUG   ( 2352):     407fc314 135c004a 0a000004 e4d6c001 e35c0044
I/DEBUG   ( 2352):     407fc324 135c004a 02477004 0a000000 e4d6c001
I/DEBUG   ( 2352):     407fc334 e35c0000 0affffd2 e35c0044 135c004a
I/DEBUG   ( 2352):     407fc344 0a000002 e497c004 e488c004 eafffff6
I/DEBUG   ( 2352):     407fc354 e2888007 e497c004 e3c88007 e4972004
I/DEBUG   ( 2352):     407fc364 e488c004 e4882004 eaffffef 00000000
I/DEBUG   ( 2352):
I/DEBUG   ( 2352): memory near r7:
I/DEBUG   ( 2352):     41104f58 00000000 00000000 41104f8c 41104f8c
I/DEBUG   ( 2352):     41104f68 62eae3a0 61d698a0 00000001 00000000
I/DEBUG   ( 2352):     41104f78 41104fa4 00000000 61d694b0 62eae3a0
I/DEBUG   ( 2352):     41104f88 41104fb8 00000000 41104fb8 00000000
I/DEBUG   ( 2352):     41104f98 00000000 00000000 41d4d4c8 41104fd4
I/DEBUG   ( 2352):     41104fa8 00000000 61d4fce0 62dcbf3e 62de49ca
I/DEBUG   ( 2352):     41104fb8 41d4d4a8 41104fe8 41104fe8 00000000
I/DEBUG   ( 2352):     41104fc8 00000000 00000000 41d45610 41105000
I/DEBUG   ( 2352):     41104fd8 00000000 61d50be0 00000000 00000000
I/DEBUG   ( 2352):     41104fe8 00000000 00000000 00000000 00000000
I/DEBUG   ( 2352):     41104ff8 00000000 00000000 40123ed0 62d40028
I/DEBUG   ( 2352):     41105008 41105034 4111d2f4 4111f888 41135ee8
I/DEBUG   ( 2352):     41105018 40123f08 00000001 62d40000 003509b0
I/DEBUG   ( 2352):     41105028 62d40000 003509b0 00000000 00000000
I/DEBUG   ( 2352):     41105038 00000000 00000000 00000000 00000000
I/DEBUG   ( 2352):     41105048 00000000 00000000 00000000 00000000
I/DEBUG   ( 2352):
I/DEBUG   ( 2352): memory near r8:
I/DEBUG   ( 2352):     be988bc0 41d4ac80 41d3f830 1d200005 641b284f
I/DEBUG   ( 2352):     be988bd0 61d698a0 40123010 00000000 407fc294
I/DEBUG   ( 2352):     be988be0 df0027ad 00000000 41d4a580 00000008
I/DEBUG   ( 2352):     be988bf0 00000000 4082b415 41104f78 62f61b36
I/DEBUG   ( 2352):     be988c00 641b2855 40123020 1d200005 00000000
I/DEBUG   ( 2352):     be988c10 40123010 4021b228 41105000 00000002
I/DEBUG   ( 2352):     be988c20 00000001 41d4a580 40123010 40848d51
I/DEBUG   ( 2352):     be988c30 40123010 41d4a580 00000003 41d4a580
I/DEBUG   ( 2352):     be988c40 40123010 40887c98 41d4cb88 40123ed0
I/DEBUG   ( 2352):     be988c50 be988cbc 61d698b4 00000001 41d4a580
I/DEBUG   ( 2352):     be988c60 00000001 61d698a0 00000428 62f7b447
I/DEBUG   ( 2352):     be988c70 00000012 00000001 be988cbc 40848ebd
I/DEBUG   ( 2352):     be988c80 62f7b447 41d4a580 62f7b447 000044f8
I/DEBUG   ( 2352):     be988c90 41105000 41d4a580 62f7b447 000044f8
I/DEBUG   ( 2352):     be988ca0 41105000 00000002 61d698a0 4021b228
I/DEBUG   ( 2352):     be988cb0 40123ed0 40849a37 62d73cfc 40123ed0
I/DEBUG   ( 2352):
I/DEBUG   ( 2352): memory near r9:
I/DEBUG   ( 2352):
I/DEBUG   ( 2352): memory near sl:
I/DEBUG   ( 2352):     401230f0 00000000 00000000 00000000 00000000
I/DEBUG   ( 2352):
I/DEBUG   ( 2352): memory near fp:
I/DEBUG   ( 2352):     be988bd4 40123010 00000000 407fc294 df0027ad
I/DEBUG   ( 2352):     be988be4 00000000 41d4a580 00000008 00000000
I/DEBUG   ( 2352):     be988bf4 4082b415 41104f78 62f61b36 641b2855
I/DEBUG   ( 2352):     be988c04 40123020 1d200005 00000000 40123010
I/DEBUG   ( 2352):     be988c14 4021b228 41105000 00000002 00000001
I/DEBUG   ( 2352):     be988c24 41d4a580 40123010 40848d51 40123010
I/DEBUG   ( 2352):     be988c34 41d4a580 00000003 41d4a580 40123010
I/DEBUG   ( 2352):     be988c44 40887c98 41d4cb88 40123ed0 be988cbc
I/DEBUG   ( 2352):     be988c54 61d698b4 00000001 41d4a580 00000001
I/DEBUG   ( 2352):     be988c64 61d698a0 00000428 62f7b447 00000012
I/DEBUG   ( 2352):     be988c74 00000001 be988cbc 40848ebd 62f7b447
I/DEBUG   ( 2352):     be988c84 41d4a580 62f7b447 000044f8 41105000
I/DEBUG   ( 2352):     be988c94 41d4a580 62f7b447 000044f8 41105000
I/DEBUG   ( 2352):     be988ca4 00000002 61d698a0 4021b228 40123ed0
I/DEBUG   ( 2352):     be988cb4 40849a37 62d73cfc 40123ed0 00000943
I/DEBUG   ( 2352):     be988cc4 41105000 0000186f 62d73cfc 41d4cb88
I/DEBUG   ( 2352):
I/DEBUG   ( 2352): memory near sp:
I/DEBUG   ( 2352):     be988bc8 1d200005 641b284f 61d698a0 40123010
I/DEBUG   ( 2352):     be988bd8 00000000 407fc294 df0027ad 00000000
I/DEBUG   ( 2352):     be988be8 41d4a580 00000008 00000000 4082b415
I/DEBUG   ( 2352):     be988bf8 41104f78 62f61b36 641b2855 40123020
I/DEBUG   ( 2352):     be988c08 1d200005 00000000 40123010 4021b228
I/DEBUG   ( 2352):     be988c18 41105000 00000002 00000001 41d4a580
I/DEBUG   ( 2352):     be988c28 40123010 40848d51 40123010 41d4a580
I/DEBUG   ( 2352):     be988c38 00000003 41d4a580 40123010 40887c98
I/DEBUG   ( 2352):     be988c48 41d4cb88 40123ed0 be988cbc 61d698b4
I/DEBUG   ( 2352):     be988c58 00000001 41d4a580 00000001 61d698a0
I/DEBUG   ( 2352):     be988c68 00000428 62f7b447 00000012 00000001
I/DEBUG   ( 2352):     be988c78 be988cbc 40848ebd 62f7b447 41d4a580
I/DEBUG   ( 2352):     be988c88 62f7b447 000044f8 41105000 41d4a580
I/DEBUG   ( 2352):     be988c98 62f7b447 000044f8 41105000 00000002
I/DEBUG   ( 2352):     be988ca8 61d698a0 4021b228 40123ed0 40849a37
I/DEBUG   ( 2352):     be988cb8 62d73cfc 40123ed0 00000943 41105000
I/DEBUG   ( 2352):
I/DEBUG   ( 2352): code around pc:
I/DEBUG   ( 2352):     00000000 ffffffff ffffffff ffffffff ffffffff
I/DEBUG   ( 2352):     00000010 ffffffff ffffffff ffffffff ffffffff
I/DEBUG   ( 2352):     00000020 ffffffff ffffffff ffffffff ffffffff
I/DEBUG   ( 2352):     00000030 ffffffff ffffffff ffffffff ffffffff
I/DEBUG   ( 2352):     00000040 ffffffff ffffffff ffffffff ffffffff
I/DEBUG   ( 2352):     00000050 ffffffff ffffffff ffffffff ffffffff
I/DEBUG   ( 2352):     00000060 ffffffff ffffffff ffffffff ffffffff
I/DEBUG   ( 2352):     00000070 ffffffff ffffffff ffffffff ffffffff
I/DEBUG   ( 2352):     00000080 ffffffff ffffffff ffffffff ffffffff
I/DEBUG   ( 2352):     00000090 ffffffff ffffffff ffffffff ffffffff
I/DEBUG   ( 2352):     000000a0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG   ( 2352):     000000b0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG   ( 2352):     000000c0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG   ( 2352):     000000d0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG   ( 2352):     000000e0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG   ( 2352):     000000f0 ffffffff ffffffff ffffffff ffffffff
I/DEBUG   ( 2352):
I/DEBUG   ( 2352): code around lr:
I/DEBUG   ( 2352):     40827210 ffc6f009 bd3e4620 0006090a 00044e46
I/DEBUG   ( 2352):     40827220 000494f8 2107b510 68004604 ffb8f009
I/DEBUG   ( 2352):     40827230 bd104620 b5374603 a801460d f7ff4619
I/DEBUG   ( 2352):     40827240 b1cdffcd 447c4c0e f5046824 f7d47057
I/DEBUG   ( 2352):     40827250 f504eb68 21007051 f7df462a b938eaea
I/DEBUG   ( 2352):     40827260 20054908 462b4a08 447a4479 eb22f7d4
I/DEBUG   ( 2352):     40827270 7057f504 eb5af7d4 f7ffa801 bd3effd3
I/DEBUG   ( 2352):     40827280 000608ae 00044dde 000494d1 b5134602
I/DEBUG   ( 2352):     40827290 a801460c f7ff4611 4807ffa1 68004478
I/DEBUG   ( 2352):     408272a0 a8016883 2b006023 f04fbf0c 240034ff
I/DEBUG   ( 2352):     408272b0 ffb8f7ff bd1c4620 00060854 4601b513
I/DEBUG   ( 2352):     408272c0 a8014614 ff8af7ff f7d44620 a801eae2
I/DEBUG   ( 2352):     408272d0 ffa8f7ff b573bd1c 46014616 e9dda801
I/DEBUG   ( 2352):     408272e0 f7ff4506 68f3ff7b d506065a 0210f106
I/DEBUG   ( 2352):     408272f0 46294620 ebfef7de e9c6e001 a8014504
I/DEBUG   ( 2352):     40827300 ff90f7ff b537bd7c 46144601 461da801
I/ServiceManager( 2349): service 'media.audio_flinger' died
I/ServiceManager( 2349): service 'media.player' died
I/ServiceManager( 2349): service 'media.camera' died
I/Netd    ( 2647): Netd 1.0 starting
W/InterfaceController( 2647): Warning (Cannot load library: load_library(linker.cpp:745): library "/system/lib/libnetcmdiface.so" not found) while opening the net interface command library
D/AndroidRuntime( 2648):
D/AndroidRuntime( 2648): >>>>>> AndroidRuntime START com.android.internal.os.ZygoteInit <<<<<<
D/AndroidRuntime( 2648): CheckJNI is OFF
I/AndroidRuntime( 2648): JNI options: '-Xjniopts:warnonly'
D/dalvikvm( 2648): Trying to load lib libjavacore.so 0x0
D/dalvikvm( 2648): Added shared lib libjavacore.so 0x0
D/dalvikvm( 2648): Trying to load lib libnativehelper.so 0x0
D/dalvikvm( 2648): Added shared lib libnativehelper.so 0x0
F/libc    ( 2648): Fatal signal 11 (SIGSEGV) at 0x00000000 (code=1), thread 2648 (zygote)
I/mediaserver( 2646): ServiceManager: 0x40a6dfb0
I/AudioFlinger( 2646): Using default 3000 mSec as standby time.
I/CameraService( 2646): CameraService started (pid=2646)
I/FslCameraHAL( 2646): Face Back Camera is ov5640_mipi, orient is 0
I/FslCameraHAL( 2646): Face Front Camera is uvc,ov5642_camera,ov5640_camera, orient is 0
I/FslCameraHAL( 2646): Checking the camera ov5640_mipi
I/FslCameraHAL( 2646): Checking the camera uvc
I/FslCameraHAL( 2646): Checking the camera ov5642_camera
I/FslCameraHAL( 2646): Checking the camera ov5640_camera
I/AudioPolicyManagerBase( 2646): loadAudioPolicyConfig() loaded /system/etc/audio_policy.conf
W/audio_hw_primary( 2646): card 0, id wm8962audio ,driver wm8962-audio, name wm8962-audio
W/audio_hw_primary( 2646): out rate 44100
W/audio_hw_primary( 2646): in rate 44100, channels 1 format 0
W/audio_hw_primary( 2646): card 1, id imxhdmisoc ,driver imx-hdmi-soc, name imx-hdmi-soc
W/audio_hw_primary( 2646): in rate 0, channels 0 format 0
I/AudioFlinger( 2646): loadHwModule() Loaded primary audio interface from Freescale i.MX Audio HW HAL (audio) handle 1
W/audio_hw_primary( 2646): open output stream devices 2, format 1, channels 3, sample_rate 44100, flag 2
W/audio_hw_primary( 2646): opened out stream...1084595496
I/AudioFlinger( 2646): HAL output buffer size 192 frames, normal mix buffer size 768 frames
I/AudioMixer( 2646): found effect "Multichannel Downmix To Stereo" from The Android Open Source Project
E/MonoPipe( 2646): Failed to fetch local time frequency when constructing a MonoPipe (res = -32).  getNextWriteTimestamp calls will be non-functional
I/DEBUG   ( 2352): pid: 2648, tid: 2648, name: zygote  >>> zygote <<<
I/DEBUG   ( 2352):     r0 bea06bbc  r1 41e9f830  r2 4001c010  r3 61ec98a0
I/DEBUG   ( 2352):     r4 4001c010  r5 00000000  r6 407cb294  r7 400b0f78
I/DEBUG   ( 2352):     r8 bea06be0  r9 400b0f78  sl 4001c020  fp bea06bf4
I/DEBUG   ( 2352):     ip 00000069  sp bea06be8  lr 407f6231  pc 00000000  cpsr 20000030
I/DEBUG   ( 2352):     d0  00f4240037a9953f  d1  0000000000000000
I/DEBUG   ( 2352):     d18 41cbd4ca9f800000  d19 3fe8000000000000
I/DEBUG   ( 2352):
I/DEBUG   ( 2352):
I/DEBUG   ( 2352):          bea06ba8  407f6361  /system/lib/libdvm.so
I/DEBUG   ( 2352):          bea06bac  407f6231  /system/lib/libdvm.so
I/DEBUG   ( 2352):          bea06bb0  41eaac80  /dev/ashmem/dalvik-heap (deleted)
I/DEBUG   ( 2352):          bea06bb4  407f6389  /system/lib/libdvm.so
I/DEBUG   ( 2352):          bea06bb8  41e9f830  [heap]
I/DEBUG   ( 2352):          bea06bbc  4001c010
I/DEBUG   ( 2352):          bea06bc0  41eaac80  /dev/ashmem/dalvik-heap (deleted)
I/DEBUG   ( 2352):          bea06bc4  41e9f830  [heap]
I/DEBUG   ( 2352):          bea06bc8  1d200005
I/DEBUG   ( 2352):          bea06bcc  64fc084f  /system/lib/libjavacore.so
I/DEBUG   ( 2352):          bea06bd0  61ec98a0  /dev/ashmem/dalvik-LinearAlloc (deleted)
I/DEBUG   ( 2352):          bea06bd4  4001c010
I/DEBUG   ( 2352):          bea06bd8  00000000
I/DEBUG   ( 2352):          bea06bdc  407cb294  /system/lib/libdvm.so (dvmPlatformInvoke+116)
I/DEBUG   ( 2352):          bea06be0  df0027ad
I/DEBUG   ( 2352):          bea06be4  00000000
I/DEBUG   ( 2352):     #00  bea06be8  41eaa580  /dev/ashmem/dalvik-heap (deleted)
I/DEBUG   ( 2352):     #01  bea06be8  41eaa580  /dev/ashmem/dalvik-heap (deleted)
I/DEBUG   ( 2352):          bea06bec  00000008
I/DEBUG   ( 2352):     #02  bea06bf0  00000000
I/DEBUG   ( 2352):          bea06bf4  407fa415  /system/lib/libdvm.so (dvmCallJNIMethod(unsigned int const*, JValue*, Method const*, Thread*)+400)
I/DEBUG   ( 2352):          bea06bf8  400b0f78
I/DEBUG   ( 2352):          bea06bfc  41c68b36  /system/framework/core.odex
I/DEBUG   ( 2352):          bea06c00  64fc0855  /system/lib/libjavacore.so
I/DEBUG   ( 2352):          bea06c04  4001c020
I/DEBUG   ( 2352):          bea06c08  1d200005
I/DEBUG   ( 2352):          bea06c0c  00000000
I/DEBUG   ( 2352):          bea06c10  4001c010
I/DEBUG   ( 2352):          bea06c14  4006f228
I/DEBUG   ( 2352):          bea06c18  410c5000  /dev/ashmem/dalvik-aux-structure (deleted)
I/DEBUG   ( 2352):          bea06c1c  00000002
I/DEBUG   ( 2352):          bea06c20  00000001
I/DEBUG   ( 2352):          bea06c24  41eaa580  /dev/ashmem/dalvik-heap (deleted)
I/DEBUG   ( 2352):          bea06c28  4001c010
I/DEBUG   ( 2352):          bea06c2c  40817d51  /system/lib/libdvm.so (dvmInitClass+1196)
I/DEBUG   ( 2352):
I/DEBUG   ( 2352):     bea06b9c 407f6215 bea06bbc 00000025 407f6361
I/DEBUG   ( 2352):     bea06bac 407f6231 41eaac80 407f6389 41e9f830
I/DEBUG   ( 2352):     bea06bbc 4001c010 41eaac80 41e9f830 1d200005
I/DEBUG   ( 2352):     bea06bcc 64fc084f 61ec98a0 4001c010 00000000
I/DEBUG   ( 2352):     bea06bdc 407cb294 df0027ad 00000000 41eaa580
I/DEBUG   ( 2352):     bea06bec 00000008 00000000 407fa415 400b0f78
I/DEBUG   ( 2352):     bea06bfc 41c68b36 64fc0855 4001c020 1d200005
I/DEBUG   ( 2352):     bea06c0c 00000000 4001c010 4006f228 410c5000
I/DEBUG   ( 2352):     bea06c1c 00000002 00000001 41eaa580 4001c010
I/DEBUG   ( 2352):     bea06c2c 40817d51 4001c010 41eaa580 00000003
I/DEBUG   ( 2352):     bea06c3c 41eaa580 4001c010 40856c98 41eacb88
I/DEBUG   ( 2352):     bea06c4c 4001ced0 bea06cbc 61ec98b4 00000001
I/DEBUG   ( 2352):     bea06c5c 41eaa580 00000001 61ec98a0 00000428
I/DEBUG   ( 2352):     bea06c6c 41c82447 00000012 00000001 bea06cbc
I/DEBUG   ( 2352):     bea06c7c 40817ebd 41c82447 41eaa580 41c82447
I/DEBUG   ( 2352):     bea06c8c 000044f8 410c5000 41eaa580 41c82447
I/DEBUG   ( 2352):
I/DEBUG   ( 2352):     41e9f810 bea071c4 4023e075 00000000 00000000
I/DEBUG   ( 2352):     41e9f820 00000000 00000000 00000000 00000023
I/DEBUG   ( 2352):     41e9f830 40854334 00000000 00000001 4001c010
I/DEBUG   ( 2352):     41e9f840 00000000 00000000 00000000 00000013
I/DEBUG   ( 2352):     41e9f850 0000002e 00000000 00000000 00000153
I/DEBUG   ( 2352):     41e9f860 7379732f 2f6d6574 6d617266 726f7765
I/DEBUG   ( 2352):     41e9f870 6f632f6b 6a2e6572 2f3a7261 74737973
I/DEBUG   ( 2352):     41e9f880 662f6d65 656d6172 6b726f77 726f632f
I/DEBUG   ( 2352):     41e9f890 756a2d65 2e74696e 3a72616a 7379732f
I/DEBUG   ( 2352):     41e9f8a0 2f6d6574 6d617266 726f7765 6f622f6b
I/DEBUG   ( 2352):     41e9f8b0 79636e75 74736163 6a2e656c 2f3a7261
I/DEBUG   ( 2352):     41e9f8c0 74737973 662f6d65 656d6172 6b726f77
I/DEBUG   ( 2352):     41e9f8d0 7478652f 72616a2e 79732f3a 6d657473
I/DEBUG   ( 2352):     41e9f8e0 6172662f 6f77656d 662f6b72 656d6172
I/DEBUG   ( 2352):     41e9f8f0 6b726f77 72616a2e 79732f3a 6d657473
I/DEBUG   ( 2352):     41e9f900 6172662f 6f77656d 742f6b72 70656c65
I/DEBUG   ( 2352):
I/DEBUG   ( 2352):     4001bff0 00000000 00000000 00000000 00000000
I/DEBUG   ( 2352):     4001c000 00000000 00000000 00000000 00000453
I/DEBUG   ( 2352):     4001c010 41bb40e0 400b0f78 61ec94b0 410c5000
I/DEBUG   ( 2352):     4001c020 00000000 00000000 bea06d08 00000000
I/DEBUG   ( 2352):     4001c030 bea06d3c 00000001 00000000 407cb400
I/DEBUG   ( 2352):     4001c040 00000000 00000000 40f08c70 400ab300
I/DEBUG   ( 2352):     4001c050 00000000 00000000 00000001 00006000
I/DEBUG   ( 2352):     4001c060 00000000 401383dc 407cb400 407d02c0
I/DEBUG   ( 2352):     4001c070 00000000 407d43bc 407d4430 407d42e0
I/DEBUG   ( 2352):     4001c080 407d4300 407d435c 00000000 00000000
I/DEBUG   ( 2352):     4001c090 00000000 00000000 00000000 00000000
I/DEBUG   ( 2352):     4001c0a0 00000000 00000000 00002000 4085b8d4
I/DEBUG   ( 2352):     4001c0b0 00000000 00000000 00000002 41e9fbf8
I/DEBUG   ( 2352):     4001c0c0 00000001 00000040 00000200 00000000
I/DEBUG   ( 2352):     4001c0d0 00000000 00000000 00000000 00000000
I/DEBUG   ( 2352):     4001c0e0 00000000 00000000 00000000 00000000
I/DEBUG   ( 2352):
I/DEBUG   ( 2352):     61ec9880 000002f6 41c3b990 41bb5ab4 00000000
I/DEBUG   ( 2352):     61ec9890 00000000 00000000 41d82f51 00000000
I/DEBUG   ( 2352):     61ec98a0 41eaa580 0000010a 00000000 00000000
I/DEBUG   ( 2352):     61ec98b0 41c82447 4001ced0 00000943 41c68b36
I/DEBUG   ( 2352):     61ec98c0 64fc0855 00000000 407fa285 00000100
I/DEBUG   ( 2352):     61ec98d0 00000000 00000000 41eaa580 0000000a
I/DEBUG   ( 2352):     61ec98e0 00010000 00000000 41c8c2f4 4001ced0
I/DEBUG   ( 2352):     61ec98f0 00000030 41c384ed 41bb5b64 00000000
I/DEBUG   ( 2352):     61ec9900 00000000 00000000 41d82f85 00000000
I/DEBUG   ( 2352):     61ec9910 00000000 0000002c 61ea1080 61ea10b8
I/DEBUG   ( 2352):     61ec9920 61ea10f0 61ea1128 61ea1160 61ea1198
I/DEBUG   ( 2352):     61ec9930 61ea11d0 61ea1208 61ea1240 61ea1278
I/DEBUG   ( 2352):     61ec9940 61ea12b0 00000004 41eacc50 0000018c
I/DEBUG   ( 2352):     61ec9950 41eacba8 00010000 00010000 00010001
I/DEBUG   ( 2352):     61ec9960 41c2b8d2 4001ced0 00000943 41c68b36
I/DEBUG   ( 2352):     61ec9970 41bb5b78 00000000 00000000 00000000
I/DEBUG   ( 2352):
I/DEBUG   ( 2352):
I/DEBUG   ( 2352):     407cb274 3497c004 3488c004 3afffff9 e2888004
I/DEBUG   ( 2352):     407cb284 eafffff9 e899000c e59bc00c e12fff3c
I/DEBUG   ( 2352):     407cb294 e3560000 159bc010 e24bd014 188c0003
I/DEBUG   ( 2352):     407cb2a4 e8bd8bc0 e1a0ce22 e59b6008 e2866001
I/DEBUG   ( 2352):     407cb2b4 e3a02000 e4d6c001 e35c0000 0a000007
I/DEBUG   ( 2352):     407cb2c4 e2822001 e35c0044 135c004a 1afffff8
I/DEBUG   ( 2352):     407cb2d4 e3120001 12822001 02822002 eafffff4
I/DEBUG   ( 2352):     407cb2e4 e2522002 43b02000 0affffe5 e04dd102
I/DEBUG   ( 2352):     407cb2f4 e3cdd004 e1a07009 e1a0800d e59b6008
I/DEBUG   ( 2352):     407cb304 e2866001 e2877008 e4d6c001 e35c0044
I/DEBUG   ( 2352):     407cb314 135c004a 0a000004 e4d6c001 e35c0044
I/DEBUG   ( 2352):     407cb324 135c004a 02477004 0a000000 e4d6c001
I/DEBUG   ( 2352):     407cb334 e35c0000 0affffd2 e35c0044 135c004a
I/DEBUG   ( 2352):     407cb344 0a000002 e497c004 e488c004 eafffff6
I/DEBUG   ( 2352):     407cb354 e2888007 e497c004 e3c88007 e4972004
I/DEBUG   ( 2352):     407cb364 e488c004 e4882004 eaffffef 00000000
I/DEBUG   ( 2352):
I/DEBUG   ( 2352):     400b0f58 00000000 00000000 400b0f8c 400b0f8c
I/DEBUG   ( 2352):     400b0f68 41bb53a0 61ec98a0 00000001 00000000
I/DEBUG   ( 2352):     400b0f78 400b0fa4 00000000 61ec94b0 41bb53a0
I/DEBUG   ( 2352):     400b0f88 400b0fb8 00000000 400b0fb8 00000000
I/DEBUG   ( 2352):     400b0f98 00000000 00000000 41ead4c8 400b0fd4
I/DEBUG   ( 2352):     400b0fa8 00000000 61eafce0 41ad2f3e 41aeb9ca
I/DEBUG   ( 2352):     400b0fb8 41ead4a8 400b0fe8 400b0fe8 00000000
I/DEBUG   ( 2352):     400b0fc8 00000000 00000000 41ea5610 400b1000
I/DEBUG   ( 2352):     400b0fd8 00000000 61eb0be0 00000000 00000000
I/DEBUG   ( 2352):     400b0fe8 00000000 00000000 00000000 00000000
I/DEBUG   ( 2352):     400b0ff8 00000000 00000000 ffffffff ffffffff
I/DEBUG   ( 2352):     400b1008 ffffffff ffffffff ffffffff ffffffff
I/DEBUG   ( 2352):     400b1018 ffffffff ffffffff ffffffff ffffffff
I/DEBUG   ( 2352):     400b1028 ffffffff ffffffff ffffffff ffffffff
I/DEBUG   ( 2352):     400b1038 ffffffff ffffffff ffffffff ffffffff
I/DEBUG   ( 2352):     400b1048 ffffffff ffffffff ffffffff ffffffff
I/DEBUG   ( 2352):
I/DEBUG   ( 2352):     bea06bc0 41eaac80 41e9f830 1d200005 64fc084f
I/DEBUG   ( 2352):     bea06bd0 61ec98a0 4001c010 00000000 407cb294
I/DEBUG   ( 2352):     bea06be0 df0027ad 00000000 41eaa580 00000008
I/DEBUG   ( 2352):     bea06bf0 00000000 407fa415 400b0f78 41c68b36
I/DEBUG   ( 2352):     bea06c00 64fc0855 4001c020 1d200005 00000000
I/DEBUG   ( 2352):     bea06c10 4001c010 4006f228 410c5000 00000002
I/DEBUG   ( 2352):     bea06c20 00000001 41eaa580 4001c010 40817d51
I/DEBUG   ( 2352):     bea06c30 4001c010 41eaa580 00000003 41eaa580
I/DEBUG   ( 2352):     bea06c40 4001c010 40856c98 41eacb88 4001ced0
I/DEBUG   ( 2352):     bea06c50 bea06cbc 61ec98b4 00000001 41eaa580
I/DEBUG   ( 2352):     bea06c60 00000001 61ec98a0 00000428 41c82447
I/DEBUG   ( 2352):     bea06c70 00000012 00000001 bea06cbc 40817ebd
I/DEBUG   ( 2352):     bea06c80 41c82447 41eaa580 41c82447 000044f8
I/DEBUG   ( 2352):     bea06c90 410c5000 41eaa580 41c82447 000044f8
I/DEBUG   ( 2352):     bea06ca0 410c5000 00000002 61ec98a0 4006f228
I/DEBUG   ( 2352):     bea06cb0 4001ced0 40818a37 41a7acfc 4001ced0
I/DEBUG   ( 2352):
I/DEBUG   ( 2352):
I/DEBUG   ( 2352):     4001c0f0 00000000 00000000 00000000 00000000
I/DEBUG   ( 2352):
I/DEBUG   ( 2352):     bea06bd4 4001c010 00000000 407cb294 df0027ad
I/DEBUG   ( 2352):     bea06be4 00000000 41eaa580 00000008 00000000
I/DEBUG   ( 2352):     bea06bf4 407fa415 400b0f78 41c68b36 64fc0855
I/DEBUG   ( 2352):     bea06c04 4001c020 1d200005 00000000 4001c010
I/DEBUG   ( 2352):     bea06c14 4006f228 410c5000 00000002 00000001
I/DEBUG   ( 2352):     bea06c24 41eaa580 4001c010 40817d51 4001c010
I/DEBUG   ( 2352):     bea06c34 41eaa580 00000003 41eaa580 4001c010
I/DEBUG   ( 2352):     bea06c44 40856c98 41eacb88 4001ced0 bea06cbc
I/DEBUG   ( 2352):     bea06c54 61ec98b4 00000001 41eaa580 00000001
I/DEBUG   ( 2352):     bea06c64 61ec98a0 00000428 41c82447 00000012
I/DEBUG   ( 2352):     bea06c74 00000001 bea06cbc 40817ebd 41c82447
I/DEBUG   ( 2352):     bea06c84 41eaa580 41c82447 000044f8 410c5000
I/DEBUG   ( 2352):     bea06c94 41eaa580 41c82447 000044f8 410c5000
I/DEBUG   ( 2352):     bea06ca4 00000002 61ec98a0 4006f228 4001ced0
I/DEBUG   ( 2352):     bea06cb4 40818a37 41a7acfc 4001ced0 00000943
I/DEBUG   ( 2352):     bea06cc4 410c5000 0000186f 41a7acfc 41eacb88
I/DEBUG   ( 2352):
I/DEBUG   ( 2352):     bea06bc8 1d200005 64fc084f 61ec98a0 4001c010
I/DEBUG   ( 2352):     bea06bd8 00000000 407cb294 df0027ad 00000000
I/DEBUG   ( 2352):     bea06be8 41eaa580 00000008 00000000 407fa415
I/DEBUG   ( 2352):     bea06bf8 400b0f78 41c68b36 64fc0855 4001c020
I/DEBUG   ( 2352):     bea06c08 1d200005 00000000 4001c010 4006f228
I/DEBUG   ( 2352):     bea06c18 410c5000 00000002 00000001 41eaa580
I/DEBUG   ( 2352):     bea06c28 4001c010 40817d51 4001c010 41eaa580
I/DEBUG   ( 2352):     bea06c38 00000003 41eaa580 4001c010 40856c98
I/DEBUG   ( 2352):     bea06c48 41eacb88 4001ced0 bea06cbc 61ec98b4
I/DEBUG   ( 2352):     bea06c58 00000001 41eaa580 00000001 61ec98a0
I/DEBUG   ( 2352):     bea06c68 00000428 41c82447 00000012 00000001
I/DEBUG   ( 2352):     bea06c78 bea06cbc 40817ebd 41c82447 41eaa580
I/DEBUG   ( 2352):     bea06c88 41c82447 000044f8 410c5000 41eaa580
I/DEBUG   ( 2352):     bea06c98 41c82447 000044f8 410c5000 00000002
I/DEBUG   ( 2352):     bea06ca8 61ec98a0 4006f228 4001ced0 40818a37
I/DEBUG   ( 2352):     bea06cb8 41a7acfc 4001ced0 00000943 410c5000
I/DEBUG   ( 2352):
I/DEBUG   ( 2352):
I/DEBUG   ( 2352):     407f6210 ffc6f009 bd3e4620 0006090a 00044e46
I/DEBUG   ( 2352):     407f6220 000494f8 2107b510 68004604 ffb8f009
I/DEBUG   ( 2352):     407f6230 bd104620 b5374603 a801460d f7ff4619
I/DEBUG   ( 2352):     407f6240 b1cdffcd 447c4c0e f5046824 f7d47057
I/DEBUG   ( 2352):     407f6250 f504eb68 21007051 f7df462a b938eaea
I/DEBUG   ( 2352):     407f6260 20054908 462b4a08 447a4479 eb22f7d4
I/DEBUG   ( 2352):     407f6270 7057f504 eb5af7d4 f7ffa801 bd3effd3
I/DEBUG   ( 2352):     407f6280 000608ae 00044dde 000494d1 b5134602
I/DEBUG   ( 2352):     407f6290 a801460c f7ff4611 4807ffa1 68004478
I/DEBUG   ( 2352):     407f62a0 a8016883 2b006023 f04fbf0c 240034ff
I/DEBUG   ( 2352):     407f62b0 ffb8f7ff bd1c4620 00060854 4601b513
I/DEBUG   ( 2352):     407f62c0 a8014614 ff8af7ff f7d44620 a801eae2
I/DEBUG   ( 2352):     407f62d0 ffa8f7ff b573bd1c 46014616 e9dda801
I/DEBUG   ( 2352):     407f62e0 f7ff4506 68f3ff7b d506065a 0210f106
I/DEBUG   ( 2352):     407f62f0 46294620 ebfef7de e9c6e001 a8014504
I/DEBUG   ( 2352):     407f6300 ff90f7ff b537bd7c 46144601 461da801
I/Netd    ( 2766): Netd 1.0 starting
W/InterfaceController( 2766): Warning (Cannot load library: load_library(linker.cpp:745): library "/system/lib/libnetcmdiface.so" not found) while opening the net interface command library
I/mediaserver( 2765): ServiceManager: 0x41203000
I/AudioFlinger( 2765): Using default 3000 mSec as standby time.
I/CameraService( 2765): CameraService started (pid=2765)
I/FslCameraHAL( 2765): Face Back Camera is ov5640_mipi, orient is 0
I/FslCameraHAL( 2765): Face Front Camera is uvc,ov5642_camera,ov5640_camera, orient is 0
I/FslCameraHAL( 2765): Checking the camera ov5640_mipi
I/FslCameraHAL( 2765): Checking the camera uvc
I/FslCameraHAL( 2765): Checking the camera ov5642_camera
I/FslCameraHAL( 2765): Checking the camera ov5640_camera
I/AudioPolicyManagerBase( 2765): loadAudioPolicyConfig() loaded /system/etc/audio_policy.conf
W/audio_hw_primary( 2765): card 0, id wm8962audio ,driver wm8962-audio, name wm8962-audio
W/audio_hw_primary( 2765): out rate 44100
W/audio_hw_primary( 2765): in rate 44100, channels 1 format 0
W/audio_hw_primary( 2765): card 1, id imxhdmisoc ,driver imx-hdmi-soc, name imx-hdmi-soc
W/audio_hw_primary( 2765): in rate 0, channels 0 format 0
I/AudioFlinger( 2765): loadHwModule() Loaded primary audio interface from Freescale i.MX Audio HW HAL (audio) handle 1
W/audio_hw_primary( 2765): open output stream devices 2, format 1, channels 3, sample_rate 44100, flag 2
W/audio_hw_primary( 2765): opened out stream...1074629696
I/AudioFlinger( 2765): HAL output buffer size 192 frames, normal mix buffer size 768 frames
I/AudioMixer( 2765): found effect "Multichannel Downmix To Stereo" from The Android Open Source Project
E/MonoPipe( 2765): Failed to fetch local time frequency when constructing a MonoPipe (res = -32).  getNextWriteTimestamp calls will be non-functional
D/MDnsDS  ( 2766): MDnsSdListener::Hander starting up
D/MDnsDS  ( 2766): MDnsSdListener starting to monitor
D/MDnsDS  ( 2766): Going to poll with pollCount 1
D/AndroidRuntime( 2981):
D/AndroidRuntime( 2981): >>>>>> AndroidRuntime START com.android.internal.os.ZygoteInit <<<<<<
D/AndroidRuntime( 2981): CheckJNI is OFF
I/AndroidRuntime( 2981): JNI options: '-Xjniopts:warnonly'
D/dalvikvm( 2981): Trying to load lib libjavacore.so 0x0
D/dalvikvm( 2981): Added shared lib libjavacore.so 0x0
D/dalvikvm( 2981): Trying to load lib libnativehelper.so 0x0
D/dalvikvm( 2981): Added shared lib libnativehelper.so 0x0
F/libc    ( 2981): Fatal signal 11 (SIGSEGV) at 0x00000000 (code=1), thread 2981 (zygote)
I/DEBUG   ( 2352): pid: 2981, tid: 2981, name: zygote  >>> zygote <<<
I/DEBUG   ( 2352):     r0 be994bbc  r1 41ea8830  r2 4006b010  r3 61ed28a0
I/DEBUG   ( 2352):     r4 4006b010  r5 00000000  r6 407aa294  r7 410bff78
I/DEBUG   ( 2352):     r8 be994be0  r9 410bff78  sl 4006b020  fp be994bf4
I/DEBUG   ( 2352):     ip 00000069  sp be994be8  lr 407d5231  pc 00000000  cpsr 20000030
I/DEBUG   ( 2352):     d0  01406f400fdad14f  d1  0000000000000000
I/DEBUG   ( 2352):     d18 41afb5a29e000000  d19 3fe8000000000000
I/DEBUG   ( 2352):     d22 0000000000000000 init: untracked pid 4291 exited
I/DEBUG   init: untracked pid 4292 exited
I/DEBUG   ( 2352):
I/DEBUG   ( 2352):
I/DEBUG   ( 2352):          be994ba8  407d5361  /system/lib/libdvm.so
I/DEBUG   ( 2352):          be994bac  407d5231  /system/lib/libdvm.so
I/DEBUG   ( 2352):          be994bb0  41eb3c80  /dev/ashmem/dalvik-heap (deleted)
I/DEBUG   ( 2352):          be994bb4  407d5389  /system/lib/libdvm.so
I/DEBUG   ( 2352):          be994bb8  41ea8830  [heap]
I/DEBUG   ( 2352):          be994bbc  4006b010
I/DEBUG   ( 2352):          be994bc0  41eb3c80  /dev/ashmem/dalvik-heap (deleted)
I/DEBUG   ( 2352):          be994bc4  41ea8830  [heap]
I/DEBUG   ( 2352):          be994bc8  1d200005
I/DEBUG   ( 2352):          be994bcc  6414484f  /system/lib/libjavacore.so
I/DEBUG   ( 2352):          be994bd0  61ed28a0  /dev/ashmem/dalvik-LinearAlloc (deleted)
I/DEBUG   ( 2352):          be994bd4  4006b010
I/DEBUG   ( 2352):          be994bd8  00000000
I/DEBUG   ( 2352):          be994bdc  407aa294  /system/lib/libdvm.so (dvmPlatformInvoke+116)
I/DEBUG   ( 2352):          be994be0  df0027ad
I/DEBUG   ( 2352):          be994be4  00000000
I/DEBUG   ( 2352):     #00  be994be8  41eb3580  /dev/ashmem/dalvik-heap (deleted)
I/DEBUG   ( 2352):     #01  be994be8  41eb3580  /dev/ashmem/dalvik-heap (deleted)
I/DEBUG   ( 2352):          be994bec  00000008
I/DEBUG   ( 2352):     #02  be994bf0  00000000
I/DEBUG   ( 2352):          be994bf4  407d9415  /system/lib/libdvm.so (dvmCallJNIMethod(unsigned int const*, JValue*, Method const*, Thread*)+400)
I/DEBUG   ( 2352):          be994bf8ERROR: v4l2 capture: slave not found!
  410bff78
I/DEBUG   ( 2352): ERROR: v4l2 capture: slave not found!
         be994bfc  41c1ab36  /sysERROR: v4l2 capture: slave not found!
I/DEBUG ERROR: v4l2 capture: slave not found!
  ( 2352):          be994c00  641ERROR: v4l2 capture: slave not found!
44855  /system/lib/libjavacore.soERROR: v4l2 capture: slave not found!
I/DEBUG   ( 2352):          be9ERROR: v4l2 capture: slave not found!
94c04  4006b020
I/DEBUG   ( 23ERROR: v4l2 capture: slave not found!
52):          be994c08  1d200005
I/DEBUG   ( 2352):          be994c0c  00000000
I/DEBUG   ( 2352):          be994c10  4006b010
I/DEBUG   ( 2352):          be994c14  401ed228
I/DEBUG   ( 2352):          be994c18  41dcb000  /dev/ashmem/dalvik-aux-structure (deleted)
I/DEBUG   ( 2352):          be994c1c  00000002
I/DEBUG   ( 2352):          be994c20  00000001
I/DEBUG   ( 2352):          be994c24  41eb3580  /dev/ashmem/dalvik-heap (deleted)
I/DEBUG   ( 2352):          be994c28  4006b010
I/DEBUG   ( 2352):          be994c2c  407f6d51  /system/lib/libdvm.so (dvmInitClass+1196)
I/DEBUG   ( 2352):
I/DEBUG   ( 2352):     be994b9c 407d5215 be994bbc 00000025 407d5361
I/DEBUG   ( 2352):     be994bac 407d5231 41eb3c80 407d5389 41ea8830
I/DEBUG   ( 2352):     be994bbc 4006b010 41eb3c80 41ea8830 1d200005
I/DEBUG   ( 2352):     be994bcc 6414484f 61ed28a0 4006b010 00000000
I/DEBUG   ( 2352):     be994bdc 407aa294 df0027ad 00000000 41eb3580
I/DEBUG   ( 2352):     be994bec 00000008 00000000 407d9415 410bff78
I/DEBUG   ( 2352):     be994bfc 41c1ab36 64144855 4006b020 1d200005
I/DEBUG   ( 2352):     be994c0c 00000000 4006b010 401ed228 41dcb000
I/DEBUG   ( 2352):     be994c1c 00000002 00000001 41eb3580 4006b010
I/DEBUG   ( 2352):     be994c2c 407f6d51 4006b010 41eb3580 00000003
I/DEBUG   ( 2352):     be994c3c 41eb3580 4006b010 40835c98 41eb5b88
I/DEBUG   ( 2352):     be994c4c 4006bed0 be994cbc 61ed28b4 00000001
I/DEBUG   ( 2352):     be994c5c 41eb3580 00000001 61ed28a0 00000428
I/DEBUG   ( 2352):     be994c6c 41c34447 00000012 00000001 be994cbc
I/DEBUG   ( 2352):     be994c7c 407f6ebd 41c34447 41eb3580 41c34447
I/DEBUG   ( 2352):     be994c8c 000044f8 41dcb000 41eb3580 41c34447
I/DEBUG   ( 2352):
I/DEBUG   ( 2352):     41ea8810 be9951c4 40293075 00000000 00000000
I/DEBUG   ( 2352):     41ea8820 00000000 00000000 00000000 00000023
I/DEBUG   ( 2352):     41ea8830 40833334 00000000 00000001 4006b010
I/DEBUG   ( 2352):     41ea8840 00000000 00000000 00000000 00000013
I/DEBUG   ( 2352):     41ea8850 0000002e 00000000 00000000 00000153
I/DEBUG   ( 2352):     41ea8860 7379732f 2f6d6574 6d617266 726f7765
I/DEBUG   ( 2352):     41ea8870 6f632f6b 6a2e6572 2f3a7261 74737973
I/DEBUG   ( 2352):     41ea8880 662f6d65 656d6172 6b726f77 726f632f
I/DEBUG   ( 2352):     41ea8890 756a2d65 2e74696e 3a72616a 7379732f
I/DEBUG   ( 2352):     41ea88a0 2f6d6574 6d617266 726f7765 6f622f6b
I/DEBUG   ( 2352):     41ea88b0 79636e75 74736163 6a2e656c 2f3a7261
I/DEBUG   ( 2352):     41ea88c0 74737973 662f6d65 656d6172 6b726f77
I/DEBUG   ( 2352):     41ea88d0 7478652f 72616a2e 79732f3a 6d657473
I/DEBUG   ( 2352):     41ea88e0 6172662f 6f77656d 662f6b72 656d6172
I/DEBUG   ( 2352):     41ea88f0 6b726f77 72616a2e 79732f3a 6d657473
I/DEBUG   ( 2352):     41ea8900 6172662f 6f77656d 742f6b72 70656c65
I/DEBUG   ( 2352):
I/DEBUG   ( 2352):     4006aff0 00000000 00000000 00000000 00000000
I/DEBUG   ( 2352):     4006b000 00000000 00000000 00000000 00000453
I/DEBUG   ( 2352):     4006b010 41b660e0 410bff78 61ed24b0 41dcb000
I/DEBUG   ( 2352):     4006b020 00000000 00000000 be994d08 00000000
I/DEBUG   ( 2352):     4006b030 be994d3c 00000001 00000000 407aa400
I/DEBUG   ( 2352):     4006b040 00000000 00000000 40eb5b70 410ba300
I/DEBUG   ( 2352):     4006b050 00000000 00000000 00000001 00006000
I/DEBUG   ( 2352):     4006b060 00000000 401303dc 407aa400 407af2c0
I/DEBUG   ( 2352):     4006b070 00000000 407b33bc 407b3430 407b32e0
I/DEBUG   ( 2352):     4006b080 407b3300 407b335c 00000000 00000000
I/DEBUG   ( 2352):     4006b090 00000000 00000000 00000000 00000000
I/DEBUG   ( 2352):     4006b0a0 00000000 00000000 00002000 4083a8d4
I/DEBUG   ( 2352):     4006b0b0 00000000 00000000 00000002 41ea8bf8
I/DEBUG   ( 2352):     4006b0c0 00000001 00000040 00000200 00000000
I/DEBUG   ( 2352):     4006b0d0 00000000 00000000 00000000 00000000
I/DEBUG   ( 2352):     4006b0e0 00000000 00000000 00000000 00000000
I/DEBUG   ( 2352):
I/DEBUG   ( 2352):     61ed2880 000002f6 41bed990 41b67ab4 00000000
I/DEBUG   ( 2352):     61ed2890 00000000 00000000 41d34f51 00000000
I/DEBUG   ( 2352):     61ed28a0 41eb3580 0000010a 00000000 00000000
I/DEBUG   ( 2352):     61ed28b0 41c34447 4006bed0 00000943 41c1ab36
I/DEBUG   ( 2352):     61ed28c0 64144855 00000000 407d9285 00000100
I/DEBUG   ( 2352):     61ed28d0 00000000 00000000 41eb3580 0000000a
I/DEBUG   ( 2352):     61ed28e0 00010000 00000000 41c3e2f4 4006bed0
I/DEBUG   ( 2352):     61ed28f0 00000030 41bea4ed 41b67b64 00000000
I/DEBUG   ( 2352):     61ed2900 00000000 00000000 41d34f85 00000000
I/DEBUG   ( 2352):     61ed2910 00000000 0000002c 61eaa080 61eaa0b8
I/DEBUG   ( 2352):     61ed2920 61eaa0f0 61eaa128 61eaa160 61eaa198
I/DEBUG   ( 2352):     61ed2930 61eaa1d0 61eaa208 61eaa240 61eaa278
I/DEBUG   ( 2352):     61ed2940 61eaa2b0 00000004 41eb5c50 0000018c
I/DEBUG   ( 2352):     61ed2950 41eb5ba8 00010000 00010000 00010001
I/DEBUG   ( 2352):     61ed2960 41bdd8d2 4006bed0 00000943 41c1ab36
I/DEBUG   ( 2352):     61ed2970 41b67b78 00000000 00000000 00000000
I/DEBUG   ( 2352):
I/DEBUG   ( 2352):
I/DEBUG   ( 2352):     407aa274 3497c004 3488c004 3afffff9 e2888004
I/DEBUG   ( 2352):     407aa284 eafffff9 e899000c e59bc00c e12fff3c
I/DEBUG   ( 2352):     407aa294 e3560000 159bc010 e24bd014 188c0003
I/DEBUG   ( 2352):     407aa2a4 e8bd8bc0 e1a0ce22 e59b6008 e2866001
I/DEBUG   ( 2352):     407aa2b4 e3a02000 e4d6c001 e35c0000 0a000007
I/DEBUG   ( 2352):     407aa2c4 e2822001 e35c0044 135c004a 1afffff8
I/DEBUG   ( 2352):     407aa2d4 e3120001 12822001 02822002 eafffff4
I/DEBUG   ( 2352):     407aa2e4 e2522002 43b02000 0affffe5 e04dd102
I/DEBUG   ( 2352):     407aa2f4 e3cdd004 e1a07009 e1a0800d e59b6008
I/DEBUG   ( 2352):     407aa304 e2866001 e2877008 e4d6c001 e35c0044
I/DEBUG   ( 2352):     407aa314 135c004a 0a000004 e4d6c001 e35c0044
I/DEBUG   ( 2352):     407aa324 135c004a 02477004 0a000000 e4d6c001
I/DEBUG   ( 2352):     407aa334 e35c0000 0affffd2 e35c0044 135c004a
I/DEBUG   ( 2352):     407aa344 0a000002 e497c004 e488c004 eafffff6
I/DEBUG   ( 2352):     407aa354 e2888007 e497c004 e3c88007 e4972004
I/DEBUG   ( 2352):     407aa364 e488c004 e4882004 eaffffef 00000000
I/DEBUG   ( 2352):
I/DEBUG   ( 2352):     410bff58 00000000 00000000 410bff8c 410bff8c
I/DEBUG   ( 2352):     410bff68 41b673a0 61ed28a0 00000001 00000000
I/DEBUG   ( 2352):     410bff78 410bffa4 00000000 61ed24b0 41b673a0
I/DEBUG   ( 2352):     410bff88 410bffb8 00000000 410bffb8 00000000
I/DEBUG   ( 2352):     410bff98 00000000 00000000 41eb64c8 410bffd4
I/DEBUG   ( 2352):     410bffa8 00000000 61eb8ce0 41a84f3e 41a9d9ca
I/DEBUG   ( 2352):     410bffb8 41eb64a8 410bffe8 410bffe8 00000000
I/DEBUG   ( 2352):     410bffc8 00000000 00000000 41eae610 410c0000
I/DEBUG   ( 2352):     410bffd8 00000000 61eb9be0 00000000 00000000
I/DEBUG   ( 2352):     410bffe8 00000000 00000000 00000000 00000000
I/DEBUG   ( 2352):     410bfff8 00000000 00000000 00000000 0000480b
I/DEBUG   ( 2352):     410c0008 00000000 00000000 00000000 00000000
I/DEBUG   ( 2352):     410c0018 00000000 00000000 00000000 00000000
I/DEBUG   ( 2352):     410c0028 00000000 00000000 00000000 00000000
I/DEBUG   ( 2352):     410c0038 00000000 00000000 00000000 00000000
I/DEBUG   ( 2352):     410c0048 00000000 00000000 00000000 00000000
I/DEBUG   ( 2352):
I/DEBUG   ( 2352):     be994bc0 41eb3c80 41ea8830 1d200005 6414484f
I/DEBUG   ( 2352):     be994bd0 61ed28a0 4006b010 00000000 407aa294
I/DEBUG   ( 2352):     be994be0 df0027ad 00000000 41eb3580 00000008
I/DEBUG   ( 2352):     be994bf0 00000000 407d9415 410bff78 41c1ab36
I/DEBUG   ( 2352):     be994c00 64144855 4006b020 1d200005 00000000
I/DEBUG   ( 2352):     be994c10 4006b010 401ed228 41dcb000 00000002
I/DEBUG   ( 2352):     be994c20 00000001 41eb3580 4006b010 407f6d51
I/DEBUG   ( 2352):     be994c30 4006b010 41eb3580 00000003 41eb3580
I/DEBUG   ( 2352):     be994c40 4006b010 40835c98 41eb5b88 4006bed0
I/DEBUG   ( 2352):     be994c50 be994cbc 61ed28b4 00000001 41eb3580
I/DEBUG   ( 2352):     be994c60 00000001 61ed28a0 00000428 41c34447
I/DEBUG   ( 2352):     be994c70 00000012 00000001 be994cbc 407f6ebd
I/DEBUG   ( 2352):     be994c80 41c34447 41eb3580 41c34447 000044f8
I/DEBUG   ( 2352):     be994c90 41dcb000 41eb3580 41c34447 000044f8
I/DEBUG   ( 2352):     be994ca0 41dcb000 00000002 61ed28a0 401ed228
I/DEBUG   ( 2352):     be994cb0 4006bed0 407f7a37 41a2ccfc 4006bed0
I/DEBUG   ( 2352):
I/DEBUG   ( 2352):
I/DEBUG   ( 2352):     4006b0f0 00000000 00000000 00000000 00000000
I/DEBUG   ( 2352):
I/DEBUG   ( 2352):     be994bd4 4006b010 00000000 407aa294 df0027ad
I/DEBUG   ( 2352):     be994be4 00000000 41eb3580 00000008 00000000
I/DEBUG   ( 2352):     be994bf4 407d9415 410bff78 41c1ab36 64144855
I/DEBUG   ( 2352):     be994c04 4006b020 1d200005 00000000 4006b010
I/DEBUG   ( 2352):     be994c14 401ed228 41dcb000 00000002 00000001
I/DEBUG   ( 2352):     be994c24 41eb3580 4006b010 407f6d51 4006b010
I/DEBUG   ( 2352):     be994c34 41eb3580 00000003 41eb3580 4006b010
I/DEBUG   ( 2352):     be994c44 40835c98 41eb5b88 4006bed0 be994cbc
I/DEBUG   ( 2352):     be994c54 61ed28b4 00000001 41eb3580 00000001
I/DEBUG   ( 2352):     be994c64 61ed28a0 00000428 41c34447 00000012
I/DEBUG   ( 2352):     be994c74 00000001 be994cbc 407f6ebd 41c34447
I/DEBUG   ( 2352):     be994c84 41eb3580 41c34447 000044f8 41dcb000
I/DEBUG   ( 2352):     be994c94 41eb3580 41c34447 000044f8 41dcb000
I/DEBUG   ( 2352):     be994ca4 00000002 61ed28a0 401ed228 4006bed0
I/DEBUG   ( 2352):     be994cb4 407f7a37 41a2ccfc 4006bed0 00000943
I/DEBUG   ( 2352):     be994cc4 41dcb000 0000186f 41a2ccfc 41eb5b88
I/DEBUG   ( 2352):
I/DEBUG   ( 2352):     be994bc8 1d200005 6414484f 61ed28a0 4006b010
I/DEBUG   ( 2352):     be994bd8 00000000 407aa294 df0027ad 00000000
I/DEBUG   ( 2352):     be994be8 41eb3580 00000008 00000000 407d9415
I/DEBUG   ( 2352):     be994bf8 410bff78 41c1ab36 64144855 4006b020
I/DEBUG   ( 2352):     be994c08 1d200005 00000000 4006b010 401ed228
I/DEBUG   ( 2352):     be994c18 41dcb000 00000002 00000001 41eb3580
I/DEBUG   ( 2352):     be994c28 4006b010 407f6d51 4006b010 41eb3580
I/DEBUG   ( 2352):     be994c38 00000003 41eb3580 4006b010 40835c98
I/DEBUG   ( 2352):     be994c48 41eb5b88 4006bed0 be994cbc 61ed28b4
I/DEBUG   ( 2352):     be994c58 00000001 41eb3580 00000001 61ed28a0
I/DEBUG   ( 2352):     be994c68 00000428 41c34447 00000012 00000001
I/DEBUG   ( 2352):     be994c78 be994cbc 407f6ebd 41c34447 41eb3580
I/DEBUG   ( 2352):     be994c88 41c34447 000044f8 41dcb000 41eb3580
I/DEBUG   ( 2352):     be994c98 41c34447 000044f8 41dcb000 00000002
I/DEBUG   ( 2352):     be994ca8 61ed28a0 401ed228 4006bed0 407f7a37
I/DEBUG   ( 2352):     be994cb8 41a2ccfc 4006bed0 00000943 41dcb000
I/DEBUG   ( 2352):
