Unable to flash imx6Q sabre sd board to emmc
rizwan_s
Hi ,
I am working on imx6Q sabre sd board.I need to flash my binaries to emmc. when i try to flash am getting the below errors.
ModuleID[2] LevelID[1]: ../imx-3.14.28_1.0.0_ga-mfg-tools.tar\imx-3.14.28_1.0.0_ga-mfg-tools\imx-3.14.28_1.0.0_ga-mfg-tools\mfgtools-with-rootfs.tar\mfgtools-with-rootfs\mfgtools\Profiles\Linux\OS Firmware\firmware\fsl-image-mfgtool-initramfs-imx6qdlsolo.cpio.gz.u-boot failed to open.errcode is 0
ModuleID[2] LevelID[1]: Parse ucl script failed, error code: 4
It is failing during the rootfs partition.
Do i need to change anything to make it work?
Rizwan Syed
Hi Rizwan
please try procedure described in attached Linux Guide
sect.4.3 Preparing an SD/MMC card to boot.
