, or the QorIQ LS2080A SDK 1.0 Quick Start Guide file, are they somewhere located I have already downloaded the LS2080A-SDK-1-0.rar, but I cannot locate them!??
I try to follow the reference guide, but where is the the aforementioned files?
Use information for the SDK 1.8. The QorIQ LS2080A SDK 1.0 uses the same commands as the SDK 1.8.
Load the “QorIQ SDK v1.8 Info Center.pdf” file using the following link:
Pavel
Greetings Pavel thank you for your response, but the link provided prints out that an error has occured, from a quick google search i have found the
Thank you
