Floating license does NOT work properly
Question asked by Phuc Le Dinh on Dec 14, 2015
Latest reply on Jan 21, 2016 by Pascal Irrle
I've successfully applied the floating licence to CodeWarrior IDE on my PC on Thursday last week.  But since today afternoon, the debug feature doesn't seem to work properly (although compilation still works ), the error is as follows:
Here is the licence details:
Detail information for product "CodeWarrior for MCU" version "10.6.4.FSL_b06015"
status: "Activated"
License model: "class com.freescale.core.ide.license.flexlm.FlexlmActivate11"
Contact Email: licensing@freescale.com
Register URL: http://www.freescale.com/cwregister
Purchase URL: http://www.freescale.com/cwmcu10
FlexLM Eval Period: 15 day(s)
GTL Server: gtlsrvr.metrowerks.com
GTL Port: 80 (8,080)
Wants Host ID: true
License file path: C:\Freescale\CW MCU v10.6.4\MCU\license.dat
flexlmFileLocator: null
flexlmFile: ${MCU_TOOLS_HOME}/license.dat
License file URL: file:/C:/Freescale/CW MCU v10.6.4/eclipse/../MCU/license.dat
Error String:
Mandatory feature keys:
StandardEditionMCU 10.5, status : LASTS_PERMANENT
Alternate Keys:
(no keys)
LM_PATH=null
License file Content (C:\Freescale\CW MCU v10.6.4\MCU\license.dat):
#CodeWarrior Development Suite - Standard Edition, Perpetual Model, Floating
#License - CodeWarrior for MCU Standard Edition (Windows - Eclipse) for IFPL
SERVER Ungerboeck DISK_SERIAL_NUM=98894400 1200
VENDOR metrowks
USE_SERVER
INCREMENT StandardEditionMCU metrowks 10.5 permanent 1 2551D9D313E2 \
VENDOR_STRING="CodeWarrior for MCU Standard Edition (Windows - \
Eclipse)" DUP_GROUP=UH ISSUER="Freescale Semiconductor" \
ISSUED=13-nov-2015 ck=49 SN="FSL - 14718707" TS_OK
The FLTOOLS debug.log content is below:
9:35:07 (lmgrd) -----------------------------------------------
9:35:07 (lmgrd)   Please Note:
9:35:07 (lmgrd)
9:35:07 (lmgrd)   This log is intended for debug purposes only.
9:35:07 (lmgrd)   In order to capture accurate license
9:35:07 (lmgrd)   usage data into an organized repository,
9:35:07 (lmgrd)   please enable report logging. Use Macrovision's
9:35:07 (lmgrd)   software license administration  solution,
9:35:07 (lmgrd)   FLEXnet Manager, to  readily gain visibility
9:35:07 (lmgrd)   into license usage data and to create
9:35:07 (lmgrd)   insightful reports on critical information like
9:35:07 (lmgrd)   license availability and usage. FLEXnet Manager
9:35:07 (lmgrd)   can be fully automated to run these reports on
9:35:07 (lmgrd)   schedule and can be used to track license
9:35:07 (lmgrd)   servers and usage across a heterogeneous
9:35:07 (lmgrd)   network of servers including Windows NT, Linux
9:35:07 (lmgrd)   and UNIX. Contact Macrovision at
9:35:07 (lmgrd)   www.macrovision.com for more details on how to
9:35:07 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
9:35:07 (lmgrd)   for your enterprise.
9:35:07 (lmgrd)
9:35:07 (lmgrd)
9:35:07 (lmgrd)
9:35:07 (lmgrd) pid 2316
9:35:08 (lmgrd) Done rereading
9:35:08 (lmgrd) FLEXnet Licensing (v11.5.0.0 build 56285 i86_n3) started on Ungerboeck (IBM PC) (12/12/2015)
9:35:08 (lmgrd) Copyright (c) 1988-2007 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved.
9:35:08 (lmgrd) US Patents 5,390,297 and 5,671,412.
9:35:08 (lmgrd) World Wide Web:  http://www.macrovision.com
9:35:08 (lmgrd) License file(s): C:\Users\Kevin\Documents\Repository\IFPL\tools\freescale-FL-Licence\license (1).dat
9:35:08 (lmgrd) lmgrd tcp-port 1200
9:35:08 (lmgrd) Starting vendor daemons ...
9:35:08 (lmgrd) Started metrowks (pid 2416)
9:35:08 (metrowks) FLEXnet Licensing version v11.5.0.0 build 56285 i86_n3
9:35:08 (metrowks) Server started on Ungerboeck for: StandardEditionMCU
9:35:08 (metrowks) EXTERNAL FILTERS are OFF
9:35:08 (lmgrd) metrowks using TCP-port 1033
15:35:11 (lmgrd) TIMESTAMP 12/12/2015
21:35:11 (lmgrd) TIMESTAMP 12/12/2015
0:00:30 (metrowks) ERROR: Non-activation-capable daemon activation invoked with non-client-request event type
3:35:11 (lmgrd) TIMESTAMP 12/13/2015
9:35:13 (lmgrd) TIMESTAMP 12/13/2015
15:35:14 (lmgrd) TIMESTAMP 12/13/2015
21:35:15 (lmgrd) TIMESTAMP 12/13/2015
0:00:58 (metrowks) ERROR: Non-activation-capable daemon activation invoked with non-client-request event type
3:35:17 (lmgrd) TIMESTAMP 12/14/2015
9:35:17 (lmgrd) TIMESTAMP 12/14/2015
10:07:12 (metrowks) TCP_NODELAY NOT enabled
10:07:19 (metrowks) UNSUPPORTED: "ProfessionalEditionMCU" (PORT_AT_HOST_PLUS   ) Kevin@Ungerboeck  (License server system does not support this feature. (-18,327:10054 ""))
10:07:19 (metrowks) UNSUPPORTED: "InternalCDE" (PORT_AT_HOST_PLUS   ) Kevin@Ungerboeck  (License server system does not support this feature. (-18,327:10054 ""))
10:07:19 (metrowks) UNSUPPORTED: "ProfessionalEditionCDE" (PORT_AT_HOST_PLUS   ) Kevin@Ungerboeck  (License server system does not support this feature. (-18,327:10054 ""))
10:07:19 (metrowks) UNSUPPORTED: "StandardEditionCDE" (PORT_AT_HOST_PLUS   ) Kevin@Ungerboeck  (License server system does not support this feature. (-18,327:10054 ""))
10:59:49 (metrowks) UNSUPPORTED: "ProfessionalEditionMCU" (PORT_AT_HOST_PLUS   ) Kevin@Ungerboeck  (License server system does not support this feature. (-18,327:10054 ""))
10:59:49 (metrowks) OUT: "StandardEditionMCU" Kevin@Ungerboeck
10:59:50 (metrowks) IN: "StandardEditionMCU" Kevin@Ungerboeck
11:06:52 (metrowks) UNSUPPORTED: "ProfessionalEditionMCU" (PORT_AT_HOST_PLUS   ) Kevin@Ungerboeck  (License server system does not support this feature. (-18,327:10054 ""))
11:06:52 (metrowks) OUT: "StandardEditionMCU" Kevin@Ungerboeck
11:06:52 (metrowks) IN: "StandardEditionMCU" Kevin@Ungerboeck
11:08:42 (metrowks) UNSUPPORTED: "ProfessionalEditionMCU" (PORT_AT_HOST_PLUS   ) Kevin@Ungerboeck  (License server system does not support this feature. (-18,327:10054 ""))
11:08:42 (metrowks) OUT: "StandardEditionMCU" Kevin@Ungerboeck
11:08:42 (metrowks) IN: "StandardEditionMCU" Kevin@Ungerboeck
11:09:27 (metrowks) UNSUPPORTED: "ProfessionalEditionMCU" (PORT_AT_HOST_PLUS   ) Kevin@Ungerboeck  (License server system does not support this feature. (-18,327:10054 ""))
11:09:27 (metrowks) OUT: "StandardEditionMCU" Kevin@Ungerboeck
11:09:27 (metrowks) IN: "StandardEditionMCU" Kevin@Ungerboeck
11:19:21 (metrowks) UNSUPPORTED: "ProfessionalEditionMCU" (PORT_AT_HOST_PLUS   ) Kevin@Ungerboeck  (License server system does not support this feature. (-18,327:10054 ""))
11:19:21 (metrowks) OUT: "StandardEditionMCU" Kevin@Ungerboeck
11:19:21 (metrowks) IN: "StandardEditionMCU" Kevin@Ungerboeck
11:19:25 (metrowks) UNSUPPORTED: "ProfessionalEditionMCU" (PORT_AT_HOST_PLUS   ) Kevin@Ungerboeck  (License server system does not support this feature. (-18,327:10054 ""))
15:35:20 (lmgrd) TIMESTAMP 12/14/2015
Could you advise what you I do to bring back debug feature? I kind of need this working urgently. I have been working on two temp licenses for two month. I very appreciate any help.
For the time being, can I request another temp license please?
Many thanks,
Kevin
