Hi All,
I am using mkl16z32 and add tss component and finally it worked for my design but the code size is 18K out of 32K, is there any way to make it smaller ?
I tried to optimize the code and it reduced it to 15K, Any Ideas ?
Also , Tried it on FRDM-KL26Z and I have the same issue.
David
Any Help ?
Hi David
Unfortunatelly the TSS library use around 18 to 20 K
Please check the following thread
Memory requirement for TSS 3.1 library.
I hope this will help you
regards
Vicente Gomez
