Stack overflow warning
michaelhuslig
This is just a warning.  I have been moving a working project from CW and MQX 3.8/4.x to KSDK and was having trouble with task delete.  It turned out that between the different compiler and the different version of MQX, I was overflowing the stack in the task.  Since it had originally been working, I never thought to check for this.
Mike
