Problems About Building Image for MFG Tool on IMX6DL
tony_l_cai
  Dear all,
     Our project is on IMX6DL, and I want to build image for MFG Tool by LTIB. Could you give me some docs in detail how to build image for MFG Tool. Thanks~
Labels (3)
Hi Tony
please look at attached Linux Guide sect.3.9 Building Manufacturing Firmware
tony_l_cai
Hi igor,
     Following the guide, run
./ltib --profile config/platform/imx/updater.profile --preconfig config/platform/imx/
imx6q_updater.cf --continue --batch
and build fail. Part of the log is following:
sudo /opt/freescale/ltib/usr/bin/rpm --root /home/dany/tony6q/ltib/rootfs --dbpath /var/lib/rpm -e --allmatches --nodeps --define '_tmppath /tmp/ltib' modeps 2>/dev/null
sudo /opt/freescale/ltib/usr/bin/rpm --root /home/dany/tony6q/ltib/rootfs --dbpath /var/lib/rpm --prefix / --ignorearch -ivh --force --excludedocs --define '_tmppath /tmp/ltib' /home/dany/tony6q/ltib/rpm/RPMS/arm/modeps-1.0-1.arm.rpm
Preparing...                ########################################### [100%]
   1:modeps                 ########################################### [100%]
f_buildrpms() returned an error, exiting
traceback:
main:572
Started: Fri Dec 11 15:46:26 2015
Ended:   Fri Dec 11 15:54:05 2015
Elapsed: 459 seconds
These packages failed to build:
ncurses procps
Build Failed
Exiting on error or interrupt
So Could I have more detail about generating image for MFG tool?
The chapter 3.9 is so simple, I can get more help. thank you ~
I am afraid more detailed document is not available.
Probably you have other builds on that machine, could you try :
./ltib –m distclean
and make fresh build
~igor
