Under the Yocto kernel 3.14.38-r0 version, sgtl5000 Driver porting problem
ferdi
Appear the following questions, ask how to debug?,tks!
sgtl5000 0-000a: Failed to get supply 'VDDA': -517
0-000a: 1200 mV normal
sgtl5000 0-000a: Failed to request supplies: -517
sgtl5000 0-000a: ASoC: failed to probe CODEC -517
imx-sgtl5000 sound-sgtl5000.15: ASoC: failed to instantiate card -517
imx-sgtl5000 sound-sgtl5000.15: snd_soc_register_card failed (-517)
platform sound-sgtl5000.15: Driver imx-sgtl5000 requests probe deferral
NET: Registered protocol family 26
Labels (3)
Hi ferdi
suggest to look at sabrelite board with sgtl5000:
linux-2.6-imx.git - Freescale i.MX Linux Tree
as for voltages, check ER1
http://cache.freescale.com/files/analog/doc/errata/SGTL5000ER.pdf
for probe error: check i2c signals with oscilloscope, also one can add printfs
to probe fuction.
ferdi
Dear igor:
     Sgtl5000 still can not work, I would like to ask you if you have a proven sgtl5000 driver source code and DTS configuration, Thank you!
Best regards!
Ferdi
Hi Ferdi
dts for sabrelite board with sgtl5000 is working configuration
~igor
ferdi
Dear igor:
     We have tried to refer to the configuration file modified, the result is the same as the driver failed to load, may I ask if you can provide verification based on the YOCTO IMX6UL system SGTL5000 driver and DTS configuration file? Thank you
Best regards!
Ferdi
Hi Ferdi
on i.MX6UL EVK WM8960 is connected on SAI port, similar configuration with SGTL5000 can be found on
I am not aware of IMX6UL system with SGTL5000 driver. In general for customization one can apply to
Professional Services:
http://www.nxp.com/pages/freescale-professional-services:PROFESSIONAL-SERVICES
ferdi
Dear igor:
     The result is the same, how can we come to your company on-site commissioning? We belong to the Shenzhen area of Guangdong province of China.
Best regards!
Ferdi
Hi Ferdi
one can contact with local fae
http://www.nxp.com/files/abstract/global/FREESCALE_SALES_OFFICES.html
