imx6ulevk platform sgtl5000 Driver porting problem
Question asked by ferdi ferdi on Dec 3, 2015
Latest reply on Oct 12, 2016 by Sourabh Das
My DTS configuration is as follows:
clocks {
            codec_osc: codec_osc {
                #clock-cells = <0>;
                compatible = "fixed-clock";
                clock-frequency = <12000000>;
vgen4_reg: vgen4 {
            regulator-min-microvolt = <1800000>;
            regulator-max-microvolt = <3300000>;
            regulator-always-on;
        reg_3p3v: 3p3v {
            compatible = "regulator-fixed";
            regulator-name = "3P3V";
            regulator-min-microvolt = <3300000>;
sound-sgtl5000 {
                compatible = "fsl,imx6ul-arm2-sgtl5000",
                           "fsl,imx-audio-sgtl5000";
                model = "imx6ul-arm2-sgtl5000";
        cpu-dai = <&sai2>;
        audio-codec = <&codec>;
                audio-routing =
                        "LINE_IN", "Line In Jack",
                        "Headphone Jack", "HP_OUT";
&i2c1 {
codec: sgtl5000@0a {
        compatible = "fsl,sgtl5000";
        reg = <0x0a>;
        clocks = <&codec_osc>;
        VDDA-supply = <&vgen4_reg>;
        VDDIO-supply = <&reg_3p3v>;
&sai2 {
    pinctrl-names = "default";
    pinctrl-0 = <&pinctrl_sai2>;
    assigned-clocks = <&clks IMX6UL_CLK_SAI2_SEL>,
              <&clks IMX6UL_CLK_SAI2>;
    assigned-clock-parents = <&clks IMX6UL_CLK_PLL4_AUDIO_DIV>;
    assigned-clock-rates = <0>, <12288000>;
    status = "okay";
Why every time you start to make an error, leading to sgtl5000 registration failed, The error function occurs in the read I2C function,Functions are as follows:
/* read chip information */
    ret = regmap_read(sgtl5000->regmap, SGTL5000_CHIP_ID, &reg);
    if (ret)
   goto disable_clk;
I2C on the other devices work properly, what is the cause of the failure of the sgtl5000 registration? Thank you!
