Hi Pavel,
we were able to locate the document and see the trace buffer in action.
We were unable to find the right settings to trace a write over PCI/and through the Core to a DDR location (0x0eb00000) .
We tried using the following settings -
Do you see something which we overlooked, or did wrong?
Thanks in advance.
It's good but i suggest to set "trace only in TRACE event" flag.
Pavel
Thanks again, Pavel!
Yes it works!
Would be great if you could tell how it works.What the "TRACE" implies?
