Idle sleep in MQX
Idle sleep in MQX
bjorn_almqvist
Hi!
I've seen that in KSDK 1.1 there was an option (a hook) for MQX_Lite to Sleep in Idle Task. Is it possible to configure MQX to sleep in the idle task or to make it enter a low power mode (VLPS or LLS) in KSDK 1.3.0.
I prefer using PEx to configure it but I'm missing out on something. And if it is possible how do you do it? :smileyhappy:
Please help.
And very much thank you all!
bjorn_almqvist
For knowledge.
The easy way to do this is to create a thread with priority just over idle_task and let it run WFI.
Thank you
soledad
Please check the below thread and let me know if this helps!!
MQX-Lite and OperationModes
Sol
