Hello!
I am using the freescale FRDM-KL46Z board with CodeWarrior.
Everytime I try to debug a code this problem happen:
"Lauching name_project_FLASH_OpenSDA has encountered a problem.... the CodeWarrior debugger does not have a Machine Object that supports executable"
and
"The connection with the debugger was interrupted, probably due to a crash
description: "CORBA connection error
Details: "Connection test failed. Reason: org.omg.CORBA.COMM_FAILURE: vmcid: SUN minor code: 201 completed: No".
I am running the CW in the windows 8.
Does someone know how to fix this problem?
Once I did find much information about it, I tried somethings:
I switched the board and still have the problem,
I uninstaller and installed and still have the problem
I would appreciate any help.
Matheus
please check if this article can help you:
Killing Me Softly: Zombies and Debugger Engines | MCU on Eclipse
Zhang Jun
