Has anyone noticed or know the reason for fb device operation (specifically fb_pan_display) hang up? Intermittently, fb_pan_display hangs up for several milliseconds even when the refresh rate is < 60 hz .
Hi Smriti
this may be caused by gpu, so recommended to install all latest patches.
For example for L3.0.35_4.1.0 BSP this is rev L3.0.101_4.1.1 with patches on
Board Support Packages (27)
