How to add Clusters and attributes on beekit?
manuelbaez
I'm working on a dimmable lamp using beekit and I would like to know how I can add attributes to the clusters.
Because I want to send some other information like voltage etc.
Manuel
EarlOrlando
Senior Contributor II
Hello Manuel,
Attributes like voltage are present in the "Electrical measurements" cluster. Please go to the section 9.1 "Electrical Measurement Cluster" in the attached document to have a closer view about it.
Earl.
EarlOrlando
Hello Manuel,
I want to share with you this document which shows how to add clusters to a ZigBee device in the BeeStack.
How to add an endpoint and a cluster to a ZigBee device in the BeeStack
Earl Ramírez.
