I am using P2020 Board onto which my software application is sending messages over UDP protocol onto Ethernet network.
After sending 507 instances of messages successfully, it give the following error:-
Segmentation Fault Unhandled Signal 11 at 000000 nip ofea4010 lr offac16c Code 30001- printed on the Console
Please suggest the appropriate solution to overcome this problem.
Test your board using the latest SDK 1.9. A few mistakes are fixed in this SDK.
Pavel
