About JPEG Decode in i.MX6Dual Lite with Android4.4.3
Question asked by yuuki on Nov 24, 2015
Latest reply on Dec 8, 2015 by Yuri Muhin
Dear all,
We want to make application of JPEG Decode using VPU.
We have the following questions.
May I have advice?
[1]
Files of different size and format cannot be decoded in succession.
When some JPEG files of the different size are decoded in succession,
Is there the method to decode in succession without performing Open/Close of VPU_Decoder?
If it is possible, may I have advice about a setting method?
[2]
A "JPEG decode result" changes by file format(before decoding).
(JPEG file => decode => YUV420 or YUV444 format)
Is there the method to fix the format of the decoded file?
(For example, formats are only YUV444.)
If it is possible, would you tell me the method with a format as RGB?
[3]
After Jpeg decode, would you tell me the method to resize?
May I have advice?
Yuuki
