I am using a TWR-K65F180M.
I am trying to run the J-Link debugger but I keep getting two errors:
- Launching Test3_Debug_Segger:
-- Details: Starting J-Link GDB Server timed out.
- Starting J-Link GDB Server
-- Details: An internal error occurred during: "Starting J-Link GDB Server".
RequestMonitor: Sequence "", result for executing step #1 = Status ERROR: org.eclipse.cdt.dsf code=10005 Request for monitor: 'RequestMonitor (ilg.gnuarmeclipse.debug.gdbjtag.dsf.GnuArmGdbServerBackend$GdbServerStep$1@1dbb90): Status OK: unknown code=0 OK null' resulted in a rejected execution exception. null, done() method called more than once
My debug configuration looks like:
Does anyone have any idea what I am doing wrong here?
Thanks so much.
Solved! Go to Solution.
Have you recently updated your Eclipse plugins? Then it might be this isssue described here: Unable to Debug after KDS Update
Does it fail just for this target, and is it working for all other boards for you?
Other than that: Check if you have some hanging processes around, see GDB Client and Server: Unlocking GDB
I hope this helps,
Erich
I hope this helps,
Erich
Actually that second link suggested repowering the board. I tried that and it did the trick. I should have tried that already.
Thanks for the tip.
I tried this already and it didn't help me. I have not recently updated the Eclipse Plugins.
