Can I use Vs = 5 VDC to supply the MPXM2053GS? The chosen instrumentation amplifier INA333 is made for 2.5 V common-mode voltage.
Solved! Go to Solution.
Hi Heiko,
Yes, it is possible to use this sensor with a supply voltage of 5V, the minimum Vs is about 3V to get right ratiometric output. The selected instrumentation amplifier should be OK.
Tomas
Hi Heiko,
Tomas
Thanks!
