Problem of Rehost for codewarrior 5.1
leipan
Hallo,
We get problem of renewing of license. We have moved the Codewarrior 5.1 to a new PC and generated new license file (License.dat). But it is always invaild!!
Does anyone have any idea?
best regards
Harrer
trytohelp
There is a problem with the license file generated for classic tool.
The IDE and Processor Expert keys could be corrupted.
To solve the problem we need to correct and re-encrypt the license file.
To do that, please contact the license team via Service Request and attach the license file you've generated.
Service Request online:
                - Go to following URL: http://www.freescale.com/TechSupport
                - Click on Create Service Request.
In case you will come to a login page.
If you are already registered with Freescale (using the Forum, subscribed to newsletter, ...)
use your Freescale login and password. Otherwise, Click on "Register Now" to get registered.
You can submit your request through the web from there.
Pascal
Freescale Technical Support
