I try to compile the MQX 4.0.2, but I face an error:
I search the whole project, there is no definition for this variable: "listensock",
So , what is going on now? Is it a bug for this version of MQX?
Before you compile your project you need to build the below libraries:
BSP, PSP, RTCS, Shell, MFS and USB.
Which device are you using?
Which project are you using?
Sol
