Recently I started working with i.MX6 Quadcore, I am trying to flash Bootloader.
I am getting an error like this ''waiting for u-boot serial console at COM4''.
So, I thought there will be either a problem with U-boot or with COM port (COM4 in my case).
To check U-boot problem - i tried flashing U-boot files (.bin & .uimage files) using MfgTool and the flash is successful.
Here I found while flashing using MfgTool the USB is in HID mode(Human Interface Device).
So I'm suspecting a problem with COM port, when i checked ref doc i found Boot ROM puts serial downloader into HID mode to flash.
My question is how can i put serial downloader into COM mode instead of HID mode?
Please help asap.
Thanks inadvance.
Solved! Go to Solution.
Hi Mahesh
iROM can not change to "COM mode", because its behaviour is hardcoded,
can not be changed.
Hi Mahesh
can not be changed.
