when USBDM add K65/K66 support?
ccry_z
pgo
Senior Contributor V
Hi Ye Richard,
K65/K66 support will be added in the next version as a kind person has donated a board to test with :smileyhappy:
bye
PS> In the interim you can try the updated device file attached.
You will need to replace the file "C:\Program Files (x86)\pgo\USBDM ....\DeviceData\arm_devices.xml" with the attached file.
