I have new installed Codewarrior v7.2 professional version on a W7, 32 Bit system. The licence is connected to a USB Dongle.
The licence for the Coldfire works fine but the Prozessor Expert works in demo mode.
Solved! Go to Solution.
Hi Thomas,
There is a problem with the web license system for all license files for classic tools.
In some case the key for Processor Expert could be corrupted.
We need to correct and re-encrypt the license file.
Please report the problem to support@freescale.com and attach your license file.
Attached you will find a temp license.
Rename it to license.dat.
Pascal
Freescale Technical Support
Hi Thomas,
Pascal
