Booting error
Booting error
varunkjayan
hi
my t4240rdb boot was working properly but now when i start it it is showing the following error idont know what happened
U-Boot 2014.07QorIQ-SDK-V1.7+g659b6a2 (Mar 30 2015 - 12:14:13)
CPU0: T4240E, Version: 2.0, (0x82480020)
Core: e6500, Version: 2.0, (0x80400120)
Clock Configuration:
  CPU0:1800 MHz, CPU1:1800 MHz, CPU2:1800 MHz, CPU3:1800 MHz,
  CPU4:1800 MHz, CPU5:1800 MHz, CPU6:1800 MHz, CPU7:1800 MHz,
  CPU8:1800 MHz, CPU9:1800 MHz, CPU10:1800 MHz, CPU11:1800 MHz,
  CCB:733.333 MHz,
  DDR:933.333 MHz (1866.667 MT/s data rate) (Asynchronous), IFC:183.333 MHz
  FMAN1: 733.333 MHz
  FMAN2: 733.333 MHz
  QMAN: 366.667 MHz
  PME: 533.333 MHz
L1: D-cache 32 KiB enabled
  I-cache 32 KiB enabled
Reset Configuration Word (RCW):
  00000000: 1607001b 18101b16 00000000 00000000
  00000010: 6c6e0848 00448c00 0c020000 f5000000
  00000020: 00000000 ee0000ee 00000000 000287fc
  00000030: 00000000 50000000 00000000 00000028
Board: T4240RDB, Board rev: 0x04 CPLD ver: 0x0401, vBank: 0
SERDES Reference Clocks:
  SERDES1=100MHz SERDES2=156.25MHz
  SERDES3=100MHz SERDES4=100MHz
I2C: ready
SPI: ready
DRAM: Initializing....using SPD
Detected UDIMM 18JSF51272AZ-1G9K1
  CCB:733.333 MHz,
  FMAN1: 733.333 MHz
  FMAN2: 733.333 MHz
  QMAN: 366.667 MHz
  PME: 533.333 MHz
I2C: ready
SPI: ready
Waiting for D_INIT timeout. Memory may not work.
  DDR: 12 GiB (DDR3, 64-bit, CL=13, ECC on)
  DDR Controller Interleaving Mode: 3-way 4KB
  DDR Chip-Select Interleaving Mode: CS0+CS1
i dont know if it is a hardware problem and replaced power supply wires but the problem still remains
