About changing the drive strength in i.MX6DQ.
keitanagashima
Senior Contributor I
Dear All,
Hello.
I have a question about changing the drive strength in IOMUX of i.MX6DQ.
My customer will use the three kind of frequency for uSDHC operation and wants to set DSE to each frequency.
1. Initialization mode : 347.22 kHz
2. High speed mode : 50 MHz
3. SDR104 mode : 208 MHz
Is it possible to change the "DSE" field at the switching the mode?
(i.e. May I change DSE during start-up)
Keita
Labels (4)
Hi Keita
yes right, one can change DSE code manually
Hi Keita
no, "DSE" can not be changed automatically
at switching the mode (SD operating frequency)
keitanagashima
Dear Igor,
Hello. Thank you for your reply.
> no, "DSE" can not be changed automatically at switching the mode (SD operating frequency)
If user adds the changing the DSE in their code manually, may one change the DSE while working?
Keita
Hi Keita
keitanagashima
Dear Igor,
OK. I got it.
I’ll have my customer change the code.
Keita
