NOR Flash Partitioning issue
chandrashekhar
Hi ,
I am trying to partition NOR Flash by modifying  .dtb file but while loading of kernel getting "ftl_cs: FTL header not found." message. What could be the reason for this ? Anything missing in .dtb configuration? Kernel boot log shows below messages.
fe8000000.nor: Found 1 x16 devices at 0x0 in 16-bit bank. Manufacturer ID 0x000089 Chip ID 0x00227e
Amd/Fujitsu Extended Query Table at 0x0040
  Amd/Fujitsu Extended Query version 1.3.
number of CFI chips: 1
7 ofpart partitions found on MTD device fe8000000.nor
Creating 7 MTD partitions on "fe8000000.nor":
0x000000020000-0x000000400000 : "csl_s"
0x000002ba0000-0x000002fa0000 : "Space Available"
0x000002fa0000-0x000003000000 : "Reserved"
0x000003000000-0x000003020000 : "NVRAM Bakup"
0x000003600000-0x000003800000 : "Upgrade Boot Rom"
0x000003800000-0x000003820000 : "NVRAM"
0x000003e00000-0x000004000000 : "Running Boot Rom"
Chandra
yipingwang
Hello Chandra,
Probably the problem is caused by Kernel configuration, please check your Kernel configuration whether "CONFIG_FTL" in enabled, if yes, please disable it and rebuild Kernel image.
Device Drivers ->
Memory Technology Devices (MTD) ->
<>FTL (Flash Translation Layer) support
If your problem remains, please provide your dts and Kernel configuration file.
Yiping
yipingwang
Hello Chandra,
Device Drivers ->
Yiping
