Hi we have a custom sabresd board in which freescale provided android lollipop
is running ,We have connected sabresd to another device (running on linux )
through ethernet interface(static IP).
Now when we connect our sabresd board to WiFi network the ethernet connection(between sabresd and other device )
doesn't works(verified by pinging )
What could be the possible reason
Himanshu
Solved! Go to Solution.
Could you please check the routing table to find the default routing interface in that time?
