ST7735
ST7735
gregorypiaskowy
Hello all I am completely new to the community so let's start with Hello All
I have this little lovely screen made by Adafruit and I was trying to connect it to s8aw60 microcontroller.
I have set the SPI module bits that I have a specified baud rate and it looks that It can communicate with the screen, however, I have problems with making microcontroller recognizing the screen. I tried to change driver provided for Arduino and other which I found on the Internet but that failed. There is no example of using s08aw60 microcontroller. Maybe someone can give me some advice?
Thank you so much
vicentegomez
Hi Gregory
I do not have a sample code for the S08AW but I have for the S08SH that have the same SPI module, please check the attached file, I also attached a presentation for the SPI module
I hope this will help you
Please let me know if you have more questions
have a good day.
gregorypiaskowy
Hi Pedro
Thank you very much for your answer. It helped me a lot :smileyhappy:
I managed to write a small program which sends bits though SPI module. I can observe the message (SPI1D) on LED bar which is mounted in my demoboard. I have a lot of problems with declaring a LCD screen. Do you have some example program for this micro controller family which links MCU and LCD screen? that would be great.
Thank you very much :smileyhappy:
Kind regards
