KDS-V3.0, Win7, MK66FX1M0VMD18
We had a project running just fine under KSDK-V1.2.
When KSDK-V1.3 arrived we updated (automatic converter) our project, and now we got some peculiar error messages:
Cannot create new item, could not load item: symbol = LinkItem item = Beans\OS_Task\Items\1.3.0\OS_Task_links.item
Cannot create new item, could not load item: symbol = SdkSpecificMethodsMasterInt item = Beans\fsl_dspi\Items\1.3.0\fsl_dspi_master_methods.item
Cannot create new item, could not load item: symbol = SdkSpecificMethodsSlaveInt item = Beans\fsl_dspi\Items\1.3.0\fsl_dspi_slave_methods.item
Cannot create new item, could not load item: symbol = SdkSpecificMethodsMasterDma item = Beans\fsl_dspi\Items\1.3.0\fsl_dspi_masterDma_methods.item
Cannot create new item, could not load item: symbol = SdkSpecificMethodsSlaveDma item = Beans\fsl_dspi\Items\1.3.0\fsl_dspi_slaveDma_methods.item
Please don't tell me to make my project from scratch, as it will take several days!!!
PS:Are the KSDK not intended for use by professionals? We have a lot of problems when update from V1.1 as well, and needless to say this is not a quality we could use for our products if this is the level of quality which is embedded in this development system.
I have discussed the issue with the responsible Processor Expert developer and the conversion of the project should be possible without any issue. Could you provide me the project for analysis, please? (I need the whole project or the ProcessorExpert.pe file from the project at least)
Marek Neuzil
