How can i store some data into flexNVM or flash memory ?
josol
Hi.
settitng :
I am using MK64FN1M0VLL12 MCU  , KDS 3.0.0,  MQX V 1.1.1
Question :
I want to store some data into NVM or flash before Power down.
and right after Power on again , I want to read the data.and i added component successfully
and i found a useful post -> Re: Erasing Flash sectors in KL25 on the Freedom Board.
and i successfully write and read a data at first time. but it didn't work at second time
while debugging, i found that in UnhandledInterrupt, the process stoped.
can i get a answer about this problem? it's my code, and debugging window. i post the problem in MQX community because it may be problem in MQX interrupt
thank you very much
(someone told me that this was happening because the sector that i was trying to write to was not erased. the PE generated code does not erase the sector for me prior to writing to it, and i have to erase it myself but i don't know how can i erase the sector , should i edit MQX??)
uint8 FromPtr[6] = {0x1F, 0x2F, 0x3F, 0x4F, 0x5F, 0x6F};
uint8 ToPtr[6];
int OpStatus;
LDD_TError OpStatus;
LDD_TDeviceData* FLASH1Pointer;
FLASH1Pointer = FLASH1_Init(NULL);
FLASH1_Erase(FLASH1Pointer, 0xFFFFA, 0x6);  //erase
  do {
  FLASH1_Main(FLASH1Pointer);
  OpStatus = FLASH1_GetOperationStatus(FLASH1Pointer);
  } while (!((OpStatus == LDD_FLASH_IDLE) | (OpStatus == LDD_FLASH_FAILED)));
  FLASH1_Write(FLASH1Pointer, FromPtr, 0xFFFFA, 0x6);  //write
  do {
  FLASH1_Read(FLASH1Pointer,0xFFFFA, ToPtr, 0x6);  //read
  do {
danielchen
Hi Jo Sol
Please check the following document for writing FlexNVM in MQX
MQX FlashX driver – how to write FlexNVM?
danielchen
Hi Jo Sol
josol
Thank you very much
