When the Interrupts of CAM and CRANK  occurred at the same time, the ISR of CAM is not executed , but the Interrupt of CRANK  is Normal, it is related to  eTPU
jwsmart
AS talked by the topic, when interrupts of cam and crank occurred at the same time, the ISR of CAM is not executed , but the Interrupt of CRANK  is Normal, it is related to  eTPU
Original Attachment has been moved to: etpu.c.rar
