FRDM-K64 (MK64FN1M0VLL12) complete datasheet
ssinfod
I'm trying to find the datasheet of the FRDM-K64 (MK64FN1M0VLL12) MCU.
I found some documents on the webpages below but it does not seem to be the complete datasheet.
I'm looking for the datasheet that lists all the registers, explain the peripherals (UART, SPI, Ethernet, Memory, etc..) and gives details about the instruction set.
Otherwise, is there a common document for the Cortex M4 ? (From Freescale or ARM ?)
Reference:
http://www.freescale.com/products/arm-processors/kinetis-cortex-m/k-series/k6x-ethernet-mcus/freesca...
http://www.freescale.com/products/arm-processors/kinetis-cortex-m/k-series/k6x-ethernet-mcus/kinetis...
ssinfod
Hello ssinfod,
Please see the attachment .
Hope it helps
Alice
Hello ssinfod,
Hope it helps
Alice
ssinfod
Thanks, this is what I was looking for.
ssinfod
Welcome !:smileyhappy:
If you click the  button of  "Correct Answer"  , i will be much appreciate with you !
Alice
izzylp
Thanks for these documents. You can't find them anywhere on NXP's website... and I would like to know why.
Hi Luis,
Sorry I also don't know why you can't find them.
About the K64 reference manual K64P144M120SF5RM.pdf, you can find on NXP website:
Arm® Cortex®-M4|Kinetis K64 120 MHz 32-bit MCUs|NXP
about the other two, it is about the ARM core document, you can find them on ARM website.
Hope it helps
TIC
